70D flywheel
plowhand
PostPosted: Sat Jan 13, 2018 4:55 pm    Post subject: 70D flywheel Reply to specific post Reply with quote
How does this flywheel look?
Mike M
PostPosted: Sun Jan 14, 2018 6:37 am    Post subject: Re: 70D flywheel Reply to specific post Reply with quote
Looks "normal" from here. But hard to see if it has any cracks in it with a picture.
Dan in Ohio
PostPosted: Sun Jan 14, 2018 8:33 am    Post subject: Re: 70D flywheel Reply to specific post Reply with quote
Like one that someone has tried to tighten using a new grade 8 nut on an original (already stretched) bolt with an oil stain on the ground. Could be a normal flywheel on a 70D that is just marking it's spot in the shed as some of mine do, hard to say just looking.
Blksmok
PostPosted: Sun Jan 14, 2018 11:14 am    Post subject: Re: 70D flywheel Reply to specific post Reply with quote
Outside of obvious cracks, you can not tell the condition just by looking. The new nuts indicate there may have been a problem in the past. Best test is to loosen the bolts and check to see if there is ANY rotational movement of the flywheel on the crankshaft. If there is both the flywheel and crankshaft splines are worn.
buickanddeere
PostPosted: Sun Jan 14, 2018 5:02 pm    Post subject: Re: 70D flywheel Reply to specific post Reply with quote
One new nut on an old bolt could be indications that some cheapskate was cutting corners during repair and service . A pair of new bolts, nuts and washers are not expensive or difficult to find .
