Weight of WD
Earle(NC)
PostPosted: Sun Jan 28, 2018 8:59 am    Post subject: Weight of WD Reply to specific post Reply with quote
Can someone give me an idea of what a stripped down (no hyd/lift) WD with wide front end, not loaded tires, would weigh. Thanks in advance
old
PostPosted: Sun Jan 28, 2018 9:13 am    Post subject: Re: Weight of WD Reply to specific post Reply with quote
Book I have says around 4000lbs
DrAllis
PostPosted: Sun Jan 28, 2018 10:19 am    Post subject: Re: Weight of WD Reply to specific post Reply with quote
My 1957 WD-45 wide front with 14.9 x 28 dry front and rear tires weighs 3600 lbs. I've pulled it a couple of times and that's what two different scales have said.
D beatty
PostPosted: Sun Jan 28, 2018 1:11 pm    Post subject: Re: Weight of WD Reply to specific post Reply with quote
I scaled my WD 45 over a certified scale when I got it and it weighed 3880. It had no weights or fluid in 14.9x28's with wide front end but had PTO and no belt pull.
Traditional Farmer
PostPosted: Mon Jan 29, 2018 12:02 am    Post subject: Re: Weight of WD Reply to specific post Reply with quote
I've seen WD's in the 3500 lb class at tractor pulls that's 3500 lbs including the driver,they were all NF and single wheel fronts though.WC's can go into the 3000 lb class and a
WC in the 3500 will out pull a WD almost every time.
