1250 cub cadet spindle bearings
Goto page 1, 2  Next
fullpull88
PostPosted: Tue Jan 30, 2018 1:46 pm    Post subject: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
Why are spindle bearings so expensive?
Cheapest I found is a&I 94 bucks or so.
Anyone have a better priced suppliers? Big
Sal
Mule Meat
PostPosted: Tue Jan 30, 2018 3:41 pm    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
It's most likely that they are trying to sell you the complete spindle assembly or the shaft, two bearings and two seals as a "kit". And if they are MTD branded they are most likely made in China.
If they are Tapered roller bearings (like older cars used) (MTD: 941-0107) you can find American made Timekin bearings for around $12 each.
I bought four Timekin bearings from Boca Bearing for $41.00 a year or so ago.
el6147
PostPosted: Tue Jan 30, 2018 4:56 pm    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
email me those A&I part no#'s.
jeffcat
PostPosted: Tue Jan 30, 2018 5:50 pm    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
As mule said about Boca bearing. Good outfit. Give them a call for the bearings you need. What you need to do is carefully take the mandril apart. Most MTD mandrels you take the belt pulley off and the spindle will fall out the bottom. You need to get the numbers from the sides of the bearings. They are ball bearings. Now really old cub cadets had tapered bearings. Don't think you have them, could be wrong but don't think so.
R Bedell
PostPosted: Wed Jan 31, 2018 2:45 am    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
Fullpull88:
You make NO mention of the Model Number of the mower deck you are working on.
If I had that, I can give you options.
Mule Meat
PostPosted: Wed Jan 31, 2018 6:23 am    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
R Bedell wrote:
(quoted from post at 03:45:27 01/31/1Cool Fullpull88:
Decks 38, 38A, 38C, 42, 44, 44A, 44C, 50, 50A and 50C all use the same bearing assembly.
Cub Cadet part #759-3479P = IH part #IH-ST745
R Bedell
PostPosted: Thu Feb 01, 2018 3:47 am    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
Mule Meat:
(A) That is an assumption on your part, that he is using one of those decks.
(B) WRONG....There were different bearing styles used on Cub Cadet Mower Decks.
Hence the reason why I asked. To get the right bearing for the right mower deck.
Butch(OH)
PostPosted: Thu Feb 01, 2018 4:06 am    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
As they said there are several types of bearings used on decks that will fit that that tractor. If it has a deck that was on it new it likely uses the unit bearings. That means that the shaft, bearings and housing are not serviceable seperately. They are $150 plus last time I looked at Parts Tree. Personally I would not put that kind of money in a deck that old and when I run into it I replace the entire deck with an older unit or sometimes when I junk a deck it will have a decent bearing assembly or two in it but most of them are pretty bad by this time.
Married2Allis
PostPosted: Thu Feb 01, 2018 4:56 pm    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
The whole spindle assembly is over $225. (gasp)
Mule Meat
PostPosted: Thu Feb 01, 2018 6:05 pm    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
R Bedell wrote:
(quoted from post at 04:47:03 02/01/1Cool Mule Meat:
Really???
Go here and scroll down to the decks...
http://www.partstree.com/parts/cub-cadet/mowers-lawn-garden-tractor/1250-2050059-2050610u-2050630-cub-cadet-garden-tractor/
Then come back and tell me what the part number/s are for the 38-50" decks that fit a 1250 Cub tractor..
I will save you the trouble.. It is part number ..IH-ST745..
Then when are done with that..
Go here and tell me what decks part number IH ST745 ST fits..
http://www.ccspecialties.org/implementparts_2.html
Russ from MN
PostPosted: Thu Feb 01, 2018 7:38 pm    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
I find it hard to believe it can't be rebuilt, the bearings themselves shouldn't be over $10 apiece. Take it apart and look for numbers, if you don't find any then measure them and look them up online. The Big Bearing Store is a good place to look, they have good charts and good prices. This is about the size I used in a Murray a few years ago.
6004-2RS 6004-ZZ Radial Ball Bearing 20X42X12
$2.09
R Bedell
PostPosted: Fri Feb 02, 2018 3:17 am    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
Mule Meat:
I do not need to go to Parts Tree. I have all the original IH/Cub Cadet Parts Manuals from 1960-1980 in my Library. Nothing better than the original manuals.
As I said before, there are different Bearings for different decks.
Charlie Proctor, owner of ccspecialties, is a long time friend of mine and he knows exactly what I am talking about. His parts manual library is greater then mine. BTW, ccspecialties is an excellent source for the ST-745 bearing.
DoubleO7
PostPosted: Fri Feb 02, 2018 8:47 am    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
Nearly all of the mower decks from about 1965 to 1980 something can be used on any Cub Cadet built in those years.
Might take a little bit of swapping mounting parts from one deck to another but not hard to do when you need to replace a deck.
After 40 years or so, you can't really assume that any CC tractor is running a deck that was originally made for that model tractor.
Hence a need to know the deck model number when searching for parts.
Butch(OH)
PostPosted: Fri Feb 02, 2018 1:32 pm    Post subject: Re: 1250 cub cadet spindle bearings Reply to specific post Reply with quote
Russ, The unit bearing type spindle cannot be rebuilt except to replace the entire unitized bearing and shaft. Look up cub cadet ST-745
Goto page 1, 2  Next
Page 1 of 2
