TO30 rear axle inner seal?
Kadbow
PostPosted: Fri Feb 02, 2018 9:27 am    Post subject: TO30 rear axle inner seal? Reply to specific post Reply with quote
A new to me TO30 that I am doing some work on. I have the rear axle pulled out and am ready to install the new inner seal. Which direction does it go? May be a dumb question but I just want to make sure I put it in right. It has a solid face and a seemed face. Thanks for the help.
miner09
PostPosted: Fri Feb 02, 2018 1:11 pm    Post subject: Re: TO30 rear axle inner seal? Reply to specific post Reply with quote
The lip or open rubber goes to the oil side. You can see the spring inside if you pull
lip back a little. Put this toward the oil. Hope this helps. Just a way I always look
at it.
Tom H.
PostPosted: Fri Feb 02, 2018 2:59 pm    Post subject: Re: TO30 rear axle inner seal? Reply to specific post Reply with quote
As miner says lip or opening towards oil source. Learned the hard way with a rear main seal and spent the rest of the day respliting the tractor
to install a new one.
Kadbow
PostPosted: Sat Feb 03, 2018 5:25 am    Post subject: Re: TO30 rear axle inner seal? Reply to specific post Reply with quote
Another question, the axle shaft is a little rough where I assume the seal sits/rubs on the shaft, will the seal seal if the shaft is not perfectly smooth?
miner09
PostPosted: Sat Feb 03, 2018 7:46 am    Post subject: Re: TO30 rear axle inner seal? Reply to specific post Reply with quote
Take fine emory cloth and smooth it.
Kadbow
PostPosted: Sat Feb 03, 2018 10:56 am    Post subject: Re: TO30 rear axle inner seal? Reply to specific post Reply with quote
Thanks for the great advice.
