Finally started on the mower
Goto page 1, 2, 3, 4  Next
SVcummins
PostPosted: Fri Feb 02, 2018 4:50 pm    Post subject: Finally started on the mower Reply to specific post Reply with quote
Decided with the good warm weather may as well get started on the no.8. Sickle mower project today need to replace the pitman stick straighten the sickle bar itself and also make a hitch to attach the 3 point hitch of a modern tractor and get a new tire and then we can cut some hay
donjr
PostPosted: Fri Feb 02, 2018 5:22 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Several suggestions. Have someone make a few new pitmans and keep at least one on hand at all times. Hickory was always my favorite. Don't pass up on a belt driven mower, or even a side mounted mower. You'd fall in love with a side mounted....
SVcummins
PostPosted: Fri Feb 02, 2018 5:34 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I've never seen one around here sickle mowers just don't exist I'd like a side mount I bet that would be nice to cut hay .the local bomgarrs supply has a whole big stock of pitmans in stock I'd like to find more of the ends so if one breaks I could just swap it out
C.Amick
PostPosted: Fri Feb 02, 2018 6:09 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
The mower doesn't have double guards on it like the new ones in the photo, does it? Aren't they singles?
SVcummins
PostPosted: Fri Feb 02, 2018 6:15 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
They make a double guard for them now supposed to make them cut better
mschwartz
PostPosted: Fri Feb 02, 2018 6:35 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
If you ever make it up to SE Washington I would make you a good deal on a parts mower, main casting was broken when prior owner tried using it to pull a dead tractor by hooking to it. Looks like it was a good mower prior to that, wrong color for any of my projects.
SVcummins
PostPosted: Fri Feb 02, 2018 7:28 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I?ll take ya up on that if I ever make it the far from home
Brown Swiss
PostPosted: Fri Feb 02, 2018 9:17 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Was looking at the bar and was wondering how you get the turtles on there? Seems to be missing the gearbox and the knives and the curtain over the top! LOL Just teasing!
SVcummins
PostPosted: Fri Feb 02, 2018 10:06 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
If I had 10,000$ I?d have a new one a them sitting here but I still would be fixin the old sickle bar anyway
SVcummins
PostPosted: Fri Feb 02, 2018 10:10 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Is there any reason I can?t use a grass board from an ih mower on my John Deere ? I know where a new old stock ih one is
TBA
PostPosted: Sat Feb 03, 2018 3:56 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Looks good
How do you like that Montizuma tool box?
mdross
PostPosted: Sat Feb 03, 2018 4:16 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Several years ago restored a #5 mower used it once to let all the new parts learn each other. Always liked this machine once adjusted they cut great and sound good doing it. Have fun with your rebuild.
Traditional Farmer
PostPosted: Sat Feb 03, 2018 4:48 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
You need to make a trip my way I have a #10 and a #50 side mowers bought them for parts to for the 350 3pt mowers,just bought a 350 for $200.
Traditional Farmer
PostPosted: Sat Feb 03, 2018 5:24 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Looks like the cutter bar has right much of a bow,when you're not using the mower stack 2 or 3 weights on the bow in the bar it'll help straighten it over time.
Briar Hill Brittanys
PostPosted: Sat Feb 03, 2018 6:17 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 21:34:06 02/02/1Cool I've never seen one around here sickle mowers just don't exist I'd like a side mount I bet that would be nice to cut hay .the local bomgarrs supply has a whole big stock of pitmans in stock I'd like to find more of the ends so if one breaks I could just swap it out
Keep an eye out for parts on eBay. Several straps on there now. Don't forget jdparts.com. It surprises me the parts they still stock for all my old stuff.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Page 1 of 4
