Finally started on the mower
Goto page Previous  1, 2, 3, 4  Next
Leroy
PostPosted: Sat Feb 03, 2018 8:25 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I cannot see a side mount working in hay as no way to make a clean 90 degree turn with them, you would have to raise bar circle to left and drop bar. The mower you have will if you get turn made correctly cut everything without raising the bar. As for the grass poard possibly depending on just how it is made at bolt to keep it from dropping down when bar is raised. There are new steel universal boards being made and used on both JD and IH and you can buy them cheaper than new old stock wood boards as those are wanted by people restoring a mower for show and therefore will pay a premium to get what they want.
Leroy
PostPosted: Sat Feb 03, 2018 8:30 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Never did a Deere but that is the way I did for the second mower and first tractor mower I bought. It was an old COOP mower that was junk when I bought it and paid $20 for it back in mid 50's. Used it for several years. Worked best on 46 Deere B and had on Farmal H and Ferguson TO30.
Leroy
PostPosted: Sat Feb 03, 2018 9:27 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
At least the knife ends are the same as the horse drawn mowers dating back to the 30's and are easy to get. Crank end is probably same but new after market are avaible as greasless units. All I would have to do for thoe parts is gi see my Amish friends and they would be way cheaper than any place else. The teeth for a hay rake are 2/3 price from Deere.
SVcummins
PostPosted: Sat Feb 03, 2018 11:04 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I was just on John Deere parts and they still have parts for this mower
SVcummins
PostPosted: Sat Feb 03, 2018 11:06 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
This one is in kinda rough shape but nothing that can?t be fixed
SVcummins
PostPosted: Sat Feb 03, 2018 11:09 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
This one is a John Deere made buy mit it?s been a good one I had it in the back of truck when I hit a guard rail going 65 and it launched the tool box about 200 feet up the road the lid popped open and scattered tools across 4 lanes of traffic had to buy a new lid and it was good to go again
carvel minne farmer
PostPosted: Sat Feb 03, 2018 11:11 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
CVPost-Traditional Farmer wrote:
(quoted from post at 06:24:14 02/03/1Cool Looks like the cutter bar has right much of a bow,when you're not using the mower stack 2 or 3 weights on the bow in the bar it'll help straighten it over time.
agree with TF. put a 4x4 block under the end of the bar, pile on some weights while your doing the other repairs.
SVcummins
PostPosted: Sat Feb 03, 2018 11:16 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
The grass board I?m thinking of is in the basement of an old farm store that is now a clothing and junk store they also have some sickles and other stuff that most people don?t even know exists they even had an nos blacksmith share for an ih Plow
SVcummins
PostPosted: Sat Feb 03, 2018 11:41 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I?ve got some extra John Deere weights around
here I think I?ll do just that
James Howell
PostPosted: Sat Feb 03, 2018 12:17 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
"Is there any reason I can?t use a grass board from an ih mower on my John Deere ?"
None.
You might consider building a grass board.
Take a look at the photos below.
Take a look at the photo below of the measurements.
Hope this helps.
C.Amick
PostPosted: Sat Feb 03, 2018 12:29 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Just make sure they are made for a cutter bar with the same thickness as yours. The depth in the cut-out of the guard has to match the bar thickness. The cutter bar thickness on my Farmall is 5/8 inch. I found some green generic guards with a "700" stamped on them that fit it.
hd6gtom
PostPosted: Sat Feb 03, 2018 7:11 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
When I was still at home I had to mow with a JD belly mower. I just hated it. Could not turn a square corner. It was slow, 1st gear wide open, mounted on a JD tractor any faster and you ran over hay, even with a brand new sickle. Your gonna have a nice old mower there.
carvel minne farmer
PostPosted: Sat Feb 03, 2018 8:14 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 23:10:53 02/02/1Cool Is there any reason I can?t use a grass board from an ih mower on my John Deere ? I know where a new old stock ih one is
why not? might have to rig up a stop to keep it from falling down to far when you pic the bar up, but should be easy.
SVcummins
PostPosted: Sat Feb 03, 2018 10:38 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Thanks for posting that I may try building one
SVcummins
PostPosted: Mon Feb 05, 2018 5:49 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Made a little more progress on the mower today found a tire out back that is the right size for the tail wheel came of a pos 855 round baler at least finally I'll get a little money back off that thing. Got the mower hitched up tomorrow I'll take the weight of the cutrerbar and see how much or if I end up needing to raise the bar a hair more to bend it more now I'm on the hunt for some 3x4 x 7/8 shaft to make the power line a little longer
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Page 2 of 4
