Finally started on the mower
Goto page Previous  1, 2, 3, 4  Next
Bret4207
PostPosted: Tue Feb 06, 2018 5:37 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
If you really intend to use that ( I used a similar model for years) then go through now and replace the pins in the knife head, make sure the holes aren't wallowed out, add new wear plates and get your lead dialed in before you even begin to worry about mounting it. Any play in the unit is going to mean clogs when you need to be cutting hay.
The Amish around us use haybine guards on their sickle mowers.
Leroy
PostPosted: Tue Feb 06, 2018 8:41 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
You are mounting it a full 2 feet too far back for it to work good. It will be like the tail wagging the dog, no control when you try to turn. Find a correct hitch and your shaft will be fine. With it set up like that you are jusk looking for an accident too happen.
SVcummins
PostPosted: Tue Feb 06, 2018 12:58 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I was going to go that route but one of the claws is broken off I will keep watching for a new piece
SVcummins
PostPosted: Tue Feb 06, 2018 7:35 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Got the tire changed cleaned up the rim the old tube was still good but the tire was easy to remove as soon as I put the ol tire spoon to the bead the whole bead ripped right off somewhere in the darkness I must have punctured the tube so I think I?ll take it to town with me and let the tire guy fix it . The wheel bearings look good ang still had good grease in em . I greased the mower and surprisingly all the zerks took grease removed the weights from the cutter bar and the bow is a little less than before but I ended up raising the bar another 2 inches as suggested and we?ll see what that does . Went to bomgarrs and they will have a new knife for the ol mower next week for 125$ . Checked the play in the pins where there cutter bar hooks the mower frame and there is zero play at all . The next job on this will be a new pto shaft and replace the pitman the guards and knife and see what it sounds like running
carvel minne farmer
PostPosted: Tue Feb 06, 2018 8:06 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
sv take that tire in with you when you go to the tire shop and keeping a straight face on ask what they'll give you for trade in Laughing
SVcummins
PostPosted: Tue Feb 06, 2018 8:32 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Or see if they have a boot big enough to fix it 😂😂
Leroy
PostPosted: Wed Feb 07, 2018 12:51 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I would say you were lucky in finding a tire as the No. 8 came with an 8" tire while earlier model No. 5 used a 9" tire.
SVcummins
PostPosted: Wed Feb 07, 2018 1:40 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
I always like it when I find something in my spare parts big that?ll work it?s a 4.80 8 and it has traction instead of smooth but I suppose this isn?t a museum quality restoration so I guess it?ll be ok
SVcummins
PostPosted: Wed Feb 07, 2018 7:58 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Got the tire fixed wheel bearings packed . Still need 8 more guards and get the new knife got the pitman stick put together . Found a piece of 3/4 7/8 shaft to make the drive line off eBay 46$ free shipping local metal suppliers swore it never existed ! Been at Napa all day trying to get new u joints couldn?t match em which is ok already checked jd parts .com they are cheaper than Napa for the right part . Next I need to get the hydraulic ram on
SVcummins
PostPosted: Thu Feb 08, 2018 5:55 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Went to the dentist today and made a trip to town to get the rest of the guards took the cutter bar off going to put er in the ol hydraulic press and get er straight. Also shimmed the hitch solid
Leroy
PostPosted: Fri Feb 09, 2018 7:50 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Just when you try to move it just watch that you do not put the front end of the tractor thru the shop wall when it will not let you turn with it hanging way too far out back. But shop wall is better than a ditch or pond. At least you would not be taking a bath completely under water that you could not get your head above.
SVcummins
PostPosted: Fri Feb 09, 2018 11:31 am    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
This tractor weighs just over 9000 pounds I hope it can handle an 560 pound mower
SVcummins
PostPosted: Fri Feb 09, 2018 3:37 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Maybe someday a mower will come to the scrap yard and I can a new claw this one is broken off at the bolt holes
SVcummins
PostPosted: Fri Feb 09, 2018 6:20 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Got the cutter bar straight as an arrow now just waiting on driveshaft material and the new knife
Leroy
PostPosted: Fri Feb 09, 2018 6:57 pm    Post subject: Re: Finally started on the mower Reply to specific post Reply with quote
Not weight of mower but quick pull on end of bar like you cought a tree.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Page 3 of 4
