Cutting a drill in half
Goto page 1, 2  Next
Ultradog MN
PostPosted: Sun Feb 04, 2018 11:57 am    Post subject: Cutting a drill in half Reply to specific post Reply with quote
I know a guy that has a 12' I think it's an MM
drill I could buy pretty reasonable. It's a
rope/mechanical lift, on rubber and has always
been shedded. Has grass seed boxes on it.
I've been thinking about buying it and make two
6 footers out of it. Keep one and sell the
other to the deer plotters.
I'm a pretty fair welder, fabricator so not
afraid of that part.
I think most of these old drills were actually
two seperate machines side by side weren't
they?
Kind of wondering if there would be any gotchas
that I haven't thought about.
Thanks.
Bob
PostPosted: Sun Feb 04, 2018 12:36 pm    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
As long as it has two individual "lifts" and metering drive "clutches" it should be doable, just have to fabricate an extra par of "spindles" and come up with suitable wheel/hub assemblies.
Leroy
PostPosted: Mon Feb 05, 2018 8:41 am    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
Friend did that with a Deere steel wheel drill, looks factory. But you would need a doner drill to get enough parts to make a second drill. So if you want narrower drill go for cutting down BUT FORGET about making a second drill. Just keep the rest for repair parts. Not only need complete extra axle assembly but hitch also and to make the parts for second it would look like crap and you could not sell enough for what you would get for the left over parts from scrap price.
Farmallb
PostPosted: Mon Feb 05, 2018 10:22 am    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
Im guessing they have only one lift mech. So now your down to making another lift mech, and 2 wheels at least.
JMS/.MN
PostPosted: Mon Feb 05, 2018 1:15 pm    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
Jerry- we talked about that many years ago when you were here...I showed you my 10 ft Moline, low rubber, mid 50s drills. Ideal to split- has a lift on each side, separate grass and grain boxes on each side. Still many around, generally 3/4/500 bux or so. You"d need a dummy wheel for each side, leave the drives intact. Check the STC, Brainerd craigslists.
Ultradog MN
PostPosted: Mon Feb 05, 2018 3:20 pm    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
Jim,
I remember that visit and talking with you about this.
That's getting to be a while ago now - 2002 I think.
Briar Hill Brittanys
PostPosted: Tue Feb 06, 2018 6:25 am    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
Don't know about MM drills. I've channeled 4 different JD drills. Three FBs, and 1 FB-A. I wanted to make 2 from 1, but each drill had a drive gear busted on one side. Built the first 3, sold them for crazy money, then found the one pictured below. It's got the small seed box, and the fertilizer section works. Originally it was a 17-7, 17 drops on 7" spacing. Now it's 8 drops, will hold about 200# of rye or similar seed.
Here's another one, 7 drops on 7", no small seed box, but the fertilizer section worked.
Ultradog MN
PostPosted: Wed Feb 07, 2018 5:07 am    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
Nice.
Cute little drills.
I had an 8' JD model EE for a few
years.
On steel, had the grass seed box.
But even an 8' needs at least a 9'
door to get it into the shed and mine
are only 8'
So it sat outside for a few years till
I felt sorry for it and sold it.
rdandersom
PostPosted: Fri Feb 09, 2018 2:13 pm    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
I've seen pictures that had 1 wheel and 3 point hitch.
Leroy
PostPosted: Fri Feb 09, 2018 2:34 pm    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
That could not have worked as the ground wheels control depth that a 3 point connot hold that close to a quarter inch in heigh or position.
SVcummins
PostPosted: Sat Feb 10, 2018 9:56 am    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
It actually works really well the springs on the openers control the depth of the seed
SVcummins
PostPosted: Sat Feb 10, 2018 10:09 am    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
We had an old IHC drill that had two separate lift clutches and two separate seed meters a drill like that would be pretty easy to split it also had two separate caster wheels
Leroy
PostPosted: Sat Feb 10, 2018 4:30 pm    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
All drills I have ever seen have a wheel at each end to carry the frame and from the frame the openers are set to depth and without those end wheels setting the frame height a 3 point will not hold a depth as should for that, same thing that a 3 point cultivator does not hold a perfect depth. That is why later 3 point cultivators have depth wheels on each gang.
SVcummins
PostPosted: Sat Feb 10, 2018 4:41 pm    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
We don?t have end wheel drills around here only press drills I would never want one after having a drill with press wheels
Leroy
PostPosted: Sun Feb 11, 2018 8:36 am    Post subject: Re: Cutting a drill in half Reply to specific post Reply with quote
Think I have seen one press wheel drill in my 74 years. Under some conditions the end wheel drills that have a press wheel behind the opener would be good but not in all planting conditions. That I would think has to be used in very dry planting conditions that we don't have around here usually.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
