lift arm repair for ACG
george md
PostPosted: Tue Feb 06, 2018 9:14 pm    Post subject: lift arm repair for ACG Reply to specific post Reply with quote
Loren,
A month or so ago you were discussing eagle hitch arm repair , I just
finished several . I replaced the tubes with heavier stock and made thicker
and longer bushings as well as new pins.
Here is a before and after , the link will take you to all the steps.
george
http://photos.imageevent.com/gmachine/caserepairs/repairsteps/websize/Imported%20from%20qu100_5274_jpgqu.jpg
more repair
george md
PostPosted: Tue Feb 06, 2018 9:18 pm    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
Before photo didn't make it , it is in the link.
george
L.Fure
PostPosted: Wed Feb 07, 2018 3:56 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
I need a little more play in the lift arms on my 300. I have a heck of a time getting anything mounted on them. It ends up involving a big hammer before I get an implement wedged between the lift arms. These are implements I have been using for years on other tractors with eagle hitch.
John Saeli
PostPosted: Wed Feb 07, 2018 5:52 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
If I had to guess, your arms got pulled in toward each other when someone put a chain thru them & pulled. Should measure 28" centers. I've corrected several with a porta power & torch.
L.Fure
PostPosted: Wed Feb 07, 2018 6:32 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
CVPost-John Saeli wrote:
(quoted from post at 14:52:32 02/07/1Cool If I had to guess, your arms got pulled in toward each other when someone put a chain thru them & pulled. Should measure 28" centers. I've corrected several with a porta power & torch.
I think mine measured 26" when I measured it. I was thinking of switching them around. I better do some measuring to make sure that would be the answer to my problem.
Adirondack case guy
PostPosted: Wed Feb 07, 2018 6:36 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
George, looks real good. Around here when the tube got pulled off the arm, a piece of strap iron got bent and welded around the tub and up on the arm top and bottom. Farmer fix. HeHe.
I have to repair the RH lift link on my 431T. The threads have warn in both halves, and don't hold. I had to wrap a light chain through the clevis and yoke to get through the summer.
Loren
Adirondack case guy
PostPosted: Wed Feb 07, 2018 6:39 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
Yup, that happened quit a lot didn't it John. Especially on those lighter arms.
Loren
John Saeli
PostPosted: Wed Feb 07, 2018 9:59 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
Yes, foolish thing to do. This is the answer!!
L.Fure
PostPosted: Wed Feb 07, 2018 11:11 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
(quoted from post at 18:59:12 02/07/1Cool Yes, foolish thing to do. This is the answer!!
I have one of those hitches. I like to use it for hooking up to my utility trailer. I also have a homemade tool bar the previous owner of one of my 400s made. It extended past the right side eagle hitch arm. He was missing his right eye and he said the hitch helped with pulling a gravity wagon up to an elevator drag. I never seen it used, because when I was around I was the one pulling in the loads. For a farmer who had been operating tractors since the cross engine days, he couldn't back a wagon worth a darn. A lot of his tractors had homemade hitches on the front of them. He always marveled at how quickly I could back a wagon into a spot.
Adirondack case guy
PostPosted: Wed Feb 07, 2018 3:52 pm    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
Yes, I now have 2 of those. Factory built.
Loren
Case Nutty 1660
PostPosted: Thu Feb 08, 2018 3:04 am    Post subject: Re: lift arm repair for ACG Reply to specific post Reply with quote
I hook to the drawbar not the EH arms,, unless I have my hitch on the arms,, I wish I had one of those as well but I will use the homemade one
cnt
