torquing connecting rod caps head bolts
jim_uny
PostPosted: Thu Feb 08, 2018 4:14 pm    Post subject: torquing connecting rod caps head bolts Reply to specific post Reply with quote
when one torques connecting rod caps or head bolts do you put some 5 weight oil on threads ? why is this done ? if not why do you leave them dry
wilma
PostPosted: Thu Feb 08, 2018 4:36 pm    Post subject: Re: torquing connecting rod caps head bolts Reply to specific post Reply with quote
The little bit of light oil on the threads lubricates just enough so you get a correct torque. If you have ever tried to thread a slightly rusted or dry nut onto a bold and noticed it "binds" a little then goes? That little bit of binding could cause a loose rod or a head gasket to fail. Hope this explanation is helpful.
rustred
PostPosted: Thu Feb 08, 2018 5:26 pm    Post subject: Re: torquing connecting rod caps head bolts Reply to specific post Reply with quote
in the auto or engine industry thread torque is taken as clean and oiled. its pretty much torque values for oiled threads. oiled threads require less torque than a dry thread. i would guess at 10 percent less.
jim_uny
PostPosted: Thu Feb 08, 2018 10:18 pm    Post subject: Re: torquing connecting rod caps head bolts Reply to specific post Reply with quote
i found this on ARP-BOLTS.COM faqs section. i think they should knew
ARPBOLT faqs section reg lube on bolts
jim_uny
PostPosted: Thu Feb 08, 2018 10:20 pm    Post subject: Re: torquing connecting rod caps head bolts Reply to specific post Reply with quote
will try again for better hyperlink to http://arp-bolts.com/p/FAQ.php
arp bolt website faqs
