Z engine vibration
johndeerered
PostPosted: Fri Feb 09, 2018 9:17 pm    Post subject: Z engine vibration Reply to specific post Reply with quote
I swapped a gleaner z engine into my wc, put wc flywheel and clutch, gleaner front crank pulley, has a vibration at all rpm, shimmed the front engine mount, is there a difference in the wc and z crank balance, do I need the pulley to match the flywheel from the wc, any help is appreciated?
Roger in Iowa
PostPosted: Sat Feb 10, 2018 11:17 am    Post subject: Re: Z engine vibration Reply to specific post Reply with quote
Engine may need the Gleaner flywheel and front pulley. They may have been balanced to the engine.
VicS
PostPosted: Sat Feb 10, 2018 12:36 pm    Post subject: Re: Z engine vibration Reply to specific post Reply with quote
It's a E Gleaner. Flywheel and front pulley balanced them selves. But poorly from factory. Also check clutch.
DrAllis
PostPosted: Sun Feb 11, 2018 4:24 am    Post subject: Re: Z engine vibration Reply to specific post Reply with quote
There have been MANY of those kind of swaps done over the years and I've never heard of one doing that. I'd have to assume it's in the flywheel/pressure plate area. I don't know why you are using the Gleaner crank pulley ?? (not that it's the problem) It doesn't like up with the WC water pump at all.
Oconnor
PostPosted: Mon Feb 12, 2018 12:09 pm    Post subject: Re: Z engine vibration Reply to specific post Reply with quote
Wc timing cover rub the timing gear?
johndeerered
PostPosted: Mon Feb 12, 2018 5:48 pm    Post subject: Re: Z engine vibration Reply to specific post Reply with quote
It till has the original timing cover, the govenor housing had a plug in it where the arm comes out and goes over to carb side, just had to knock out plug and put wd shaft in it, easy to do, I'm gonna take flywheel off and look over good must be there.
johndeerered
PostPosted: Fri Feb 16, 2018 7:57 pm    Post subject: Re: Z engine vibration Reply to specific post Reply with quote
Found a couple of dirt dobber nest inside the flywheel, could that be enough weight to vibrate.
VicS
PostPosted: Sat Feb 17, 2018 3:51 pm    Post subject: Re: Z engine vibration Reply to specific post Reply with quote
Bound to help. I'd get everything balanced while it's apart.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
