C301 governor
mfro75
PostPosted: Sun Feb 11, 2018 7:38 am    Post subject: C301 governor Reply to specific post Reply with quote
My question is instead of using bailing wire on governor spring can I lighten weights to get 20% over stock rpms. And would this make the throttle more snappy... or is stiffening the spring going to do same thing... also if I was to lighten weights how much? Drill holes or grind some off and weight on scale and match them?
VicS
PostPosted: Sun Feb 11, 2018 10:51 am    Post subject: Re: C301 governor Reply to specific post Reply with quote
I took 20%.off last time, and a stronger spring, trying for 3500. Got it but hunts to much. When hooked to a load you have just one chance to let the clutch out. So just try 10% first. We used a postage scale. Also down at your foot on the right side I lengthen the pivot point so will pull rod farther and still push gov back to idle. Ended up with a lever on right fender hooked direct to carb.
Oconnor
PostPosted: Mon Feb 12, 2018 12:10 pm    Post subject: Re: C301 governor Reply to specific post Reply with quote
C200 governor.
Bob 7337
PostPosted: Wed Feb 14, 2018 7:05 pm    Post subject: Re: C301 governor Reply to specific post Reply with quote
Just take weights off and control it with your throttle hand
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
