89 JCB 1400 Backhoe no neutral
wjcastle
PostPosted: Mon Feb 12, 2018 8:57 am    Post subject: 89 JCB 1400 Backhoe no neutral Reply to specific post Reply with quote
Hello, I have a 1989 JCB 1400 backhoe/loader. When I move the foward/reverse lever on the steering column to the neutral position, it puts the tractor in reverse. Also when I press the clutch petal, I hear the switch clicking, but it does not disengage the clutch. Could this be a problem with the foward/reverse lever, or the foward/reverse shuttle mounted on the transmission?
thank you.
AJ.
PostPosted: Tue Feb 13, 2018 4:07 am    Post subject: Re: 89 JCB 1400 Backhoe no neutral Reply to specific post Reply with quote
More than likely the switch,I have changed lots of them,having said that the switch is expensive and you need to know its failed before you buy a new one,the switch controls the neutral start,back-up beeper as well as forward and reverse,trace the wiring going to the two solenoids on the shuttle,disconnect the plug,start up,check to see it's in neutral if so the switch is the culprit.
AJ
wjcastle
PostPosted: Tue Feb 13, 2018 8:18 am    Post subject: Re: 89 JCB 1400 Backhoe no neutral Reply to specific post Reply with quote
AJ. wrote:
(quoted from post at 05:07:39 02/13/1Cool More than likely the switch,I have changed lots of them,having said that the switch is expensive and you need to know its failed before you buy a new one,the switch controls the neutral start,back-up beeper as well as forward and reverse,trace the wiring going to the two solenoids on the shuttle,disconnect the plug,start up,check to see it's in neutral if so the switch is the culprit.
AJ
Thank you, AJ.
Are you talking about the lever switch on the steering column?
Will
AJ.
PostPosted: Tue Feb 13, 2018 2:01 pm    Post subject: Re: 89 JCB 1400 Backhoe no neutral Reply to specific post Reply with quote
Yes the forward reverse switch on the column can wear out,the two solenoids that control the forward/reverse clutches are spring loaded to go to the neutral position when the switch is in neutral so by disconnecting the plug you will know which has an issue.
AJ
1130Leo
PostPosted: Thu Mar 01, 2018 1:24 pm    Post subject: Re: 89 JCB 1400 Backhoe no neutral Reply to specific post Reply with quote
I have a 1400B, had similar issue, no reverse. The switch appeared to be ok, until we checked it using an Oscilloscope, which proved the switch was malfunctioning. Was around $300 or so for the switch,
and yes it is on the column.
