Tea20 Footrest bolts
kaesark
PostPosted: Mon Feb 12, 2018 1:44 pm    Post subject: Tea20 Footrest bolts Reply to specific post Reply with quote
Hi
Have discovered that one of the footrest bolts has sheared off at the start of the thread.
Does anyone know how much thread is on the end of the bolt as I would like to try and drill it out. I presume the bolt does not go through the casing completely.
Cheers
kaesark
PostPosted: Mon Feb 12, 2018 1:48 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
John Deere D
PostPosted: Mon Feb 12, 2018 2:12 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
Quote:
Hi
Cheers
I had the same challenge once:
Double NUT STUD and check for depth in blind hole:
I welded a WASHER to the end of the Brocken stud, then welded a NUT to the washer and backed Brocken stud out:
Bob..
kaesark
PostPosted: Mon Feb 12, 2018 2:17 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
Hi
Unfortunately I have nothing to weld to as it has broken off inside the bottom of the hole.
Cheers
John Deere D
PostPosted: Mon Feb 12, 2018 2:20 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
Hi.......
Double NUT STUD, (one of the other studs), remove and check for depth in blind hole:
Bob........
kaesark
PostPosted: Mon Feb 12, 2018 2:25 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
Ok got it, hope it doesn't break off too😂
What do you think an easyout
Will remove it.
John Deere D
PostPosted: Mon Feb 12, 2018 2:47 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
With the attaching components that hold the radius rods in place removed, is there any Brocken STUD protruding out from the threaded bore?
Bob..
Steve@Advance
PostPosted: Mon Feb 12, 2018 6:21 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
Be very careful with the ezout.
It will only work if the bolt is free to turn. If it is bottomed out, rusted, or seized, no the ezout will not work and if broken off in the bolt, the problem is made worse!
If you can score a left handed drill bit, all the better. It just "mite" grab the bolt and spin it out.
Otherwise, make every effort to drill EXACTLY in the middle, and as straight as possible. If it doesn't move, the end result will be to drill the body of the bolt away and surgically tap the remaining threads out.
That is why it is so important to keep it in the center and straight.
kaesark
PostPosted: Mon Feb 12, 2018 8:29 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
Ok I have managed to plug to bolt hole full of wd40 rust penatrant will see what happens tomorrow will go with the left hand drill bit tomorrow after its had a good soak.
kaesark
PostPosted: Tue Feb 13, 2018 5:36 pm    Post subject: Re: Tea20 Footrest bolts Reply to specific post Reply with quote
Managed to extract what was left of bolt which was only the threaded end.
Fitted new water pump as well ready for painting, then wiring to nut out.
Thanks for all the help.
