lift pump
grizz02
PostPosted: Wed Feb 14, 2018 4:31 pm    Post subject: lift pump Reply to specific post Reply with quote
I'm, replacing leaking fuel lift pump any tricks or is it just straight forward 2000 new Holland tn75 thanks
4520BW
PostPosted: Wed Feb 14, 2018 4:54 pm    Post subject: Re: lift pump Reply to specific post Reply with quote
Hey grizz..I never had to change the pump on mine but my reverser sometimes will not work and I have to go toward then reverse...you ever have this happen?
Keith Molden
PostPosted: Wed Feb 14, 2018 5:33 pm    Post subject: Re: lift pump Reply to specific post Reply with quote
Most pump arms fit under the cam lobe. just bump the starter till the cam is in the right position (high enough you can get the pump arm in the hold and get the bolts started into the block. You can determine from looking at the pump arm where it should ride, just make sure you get it in the right place or you will not be able to bolt it up, however, a little resistance on the arm is not a bad thing. Really pretty easy if you just use the kiss method & you'll be good. Keith
grizz02
PostPosted: Wed Feb 14, 2018 5:57 pm    Post subject: Re: lift pump Reply to specific post Reply with quote
no are you talking about the shuttle lever?
VicS
PostPosted: Wed Feb 14, 2018 7:38 pm    Post subject: Re: lift pump Reply to specific post Reply with quote
My son's Kubota started doing that. Was the switches right at the steering wheel. Just needed cleaned. Points were out in the open under the plastic cover.
