560 diesel
j15tractors
PostPosted: Sun Mar 04, 2018 9:35 pm    Post subject: 560 diesel Reply to specific post Reply with quote
I just bought a 560 diesel that dose not run the story i got from the guy was he was using it and parked it went to start it a month later to push snow and said it wouldn't start and said it had developed knock. I just got it home and put in the shop so i haven't had any time to mess with to much yet, but while cranking there is no smoke coming from the exhaust. thanks in advance. Just made and an account!
Dieseltech
PostPosted: Mon Mar 05, 2018 5:13 am    Post subject: Re: 560 diesel Reply to specific post Reply with quote
Loosen all six injector line nuts, tap the line ends to make sure the ermeto style ends come loose as they can stick in tight. Make sure there's fuel, stop knob pushed in too. If injection pump is working you should see fuel at each injector when cranking engine over. If not, pump MAY have several parts stuck inside, plungers, metering valve, delivery valve. are what I see most. Worst case is a seized hydraulic head rotor and broken drive shaft in the pump. Tip I use a lot on that engine is to remove all six glow plugs, makes cranking easier for faster fuel system bleeding. When system is bled you will see air-fuel mist blow out each glow plug hole, when you see that replace the plugs and engine will start easily after heating the plugs.
j15tractors
PostPosted: Tue Mar 06, 2018 5:17 pm    Post subject: Re: 560 diesel Reply to specific post Reply with quote
I did as you said but in the process 1 glow plug broke off I was getting fuel mist but still no start even with a shot of starting fluid what else can I do? It is in a 70? building and it is plugged in. Thanks.
