I need remotes on my WD
Goto page Previous  1, 2
Lotw
PostPosted: Fri Apr 13, 2018 4:13 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
My current 3 point setup probably wont allow for a factory draw bar, but it will be easy to fab one. It definitely needs one anyway, I'm not 100% happy with the spreader bar setup.
Lotw
PostPosted: Fri Apr 13, 2018 9:42 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
of course pictures always help.
old
PostPosted: Fri Apr 13, 2018 11:33 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
My WD45 has a 3 point and the factory draw bar. I also have a WD parts tractor and I think it still has the draw bar on it that I would sell
JMS/.MN
PostPosted: Fri Apr 13, 2018 1:30 pm    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
Follow the hyd hose from the cyl, back to the top center of the tractor...two hoses attach to two ports on top of the hyd valve. There is a third (not four) port there. Remove the plug and attach your remote valve there. Put a factory drawbar on the tractor to pull the planter. When you raise the Lift-Lower lever, the hyd arms will come up, then oil flows into the remote coupler. If you don"t find the factory steel line, just use a hose and a Pioneer female coupler.
Lotw
PostPosted: Mon Apr 16, 2018 4:00 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
Thanks again guys! I will be doing this!
which valve should I be buying for this?
Lotw
PostPosted: Mon Apr 16, 2018 4:02 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
would a single spool log splitter valve work?
Butch(OH)
PostPosted: Mon Apr 16, 2018 4:57 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
I think he had a typo there, where he said attach the valve I think he meant attach the line. you do not need an additional valve.
Lotw
PostPosted: Mon Apr 16, 2018 6:27 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
got ya!
JMS/.MN
PostPosted: Thu Apr 19, 2018 7:22 pm    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
Transport valve is a totally different thing-you don"t need that to run a remote cyl on a WD. Or WD45, or D17.
JMS/.MN
PostPosted: Mon Apr 23, 2018 11:42 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
Yup, I didn"t catch that. Attach the line to the port is right.
Lotw
PostPosted: Wed Jun 27, 2018 10:19 am    Post subject: Re: I need remotes on my WD Reply to specific post Reply with quote
I thought I should update this.
I added the hydraulic line as suggested. I put in a 5" nipple and a 45 degree fitting then a hose. the end is currently just laying over the rear axle and isn't mounted up. I will do that some rainy day. It works great! I cant believe it didn't come that way!
Post new topic    Yesterday's Tractors Forum Index -> Using Your Tractor & Crop Talk All times are GMT - 8 Hours
Page 2 of 2
