m5 pto stuck
m5
PostPosted: Sun Apr 22, 2007 5:47 pm    Post subject: m5 pto stuck Reply to specific post Reply with quote
JUST BOUGHT M5, NEW TO MM. PTO LEVER DOESNT MOVE SEEMS TO BE IN REAR POSION BUT THE PTO DOESNT SHUT OFF. FORWARD ON REARWARD OFF?
Kevin Moschenrose
PostPosted: Sun Apr 22, 2007 7:41 pm    Post subject: Re: m5 pto stuck Reply to specific post Reply with quote
I just got mine unstuck on my jetstar. I had to remove the three point rock shaft and the rear end housing cover to get to mine. I found that it was stuck due to be stored for some time and moisture in the rear end had flashed keeping it stuck over center. These are pretty muck the same on the two tractors.
schrocky
PostPosted: Mon Apr 23, 2007 1:52 am    Post subject: Re: m5 pto stuck Reply to specific post Reply with quote
Fwd is on back is off. They will creap because of no PTO brake but if they do not stop under load yes open it up something has went amiss
schrocky
PostPosted: Mon Apr 23, 2007 1:55 am    Post subject: Re: m5 pto stuck Reply to specific post Reply with quote
Fwd is on back is off. They will creap because of no pto brake. If it does not stop under load then yes something has went amiss and you need to open it up
ed dornbush
PostPosted: Tue Apr 24, 2007 4:53 am    Post subject: Re: m5 pto stuck Reply to specific post Reply with quote
MINE DOES THAT ,ALL I DO IS STEP ON BRAKES AND IT STOPS DON'T NO Y
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
