Converting to 12 volt
Mark Taylor
PostPosted: Fri Apr 13, 2018 1:57 pm    Post subject: Converting to 12 volt Reply to specific post Reply with quote
I am about to install a conversion kit on my Ford 2000 gas 4 cylinder but need a few pointers I have a four pole solenoid and need to know what hat I should do an if anybody has a good wire diagram to post would be nice
old
PostPosted: Sat Apr 14, 2018 9:47 am    Post subject: Re: Converting to 12 volt Reply to specific post Reply with quote
The kit should have a diagram with it. So is it a one wire or a 3 wire makes a difference. 1 wire has only one wire and it goes to the amp gauge. 3 wire has 3 wires and the charge wire goes to the amp gauge and the #2 wire on the plug goes to the charge stud on the alternator and the #1 wire goes to the ignition switch the side that is hot when turned on but you are likely to need a diode or light bulb in line or it will not shut off due to alternator back feed
Mark Taylor
PostPosted: Sat Apr 14, 2018 4:08 pm    Post subject: Re: Converting to 12 volt Reply to specific post Reply with quote
[quote="Mark Taylor"](quoted from post at 14:57:32 04/13/1Cool I am about to install a conversion kit on my 1964 Ford 2000 gas 4 cylinder i have a four pole solenoid with 2 large post and 2small post marked s and I . With all the old wire with cracked insulation or painted and faded not able to make out the color I am wanting to rewire the whole thing and need to know what I should do an if anybody has a good wire diagram to go by lights are not important at this time .
old
PostPosted: Sun Apr 15, 2018 9:26 am    Post subject: Re: Converting to 12 volt Reply to specific post Reply with quote
Wring a tractor like yours is easy and I can almost do it in my sleep but I at one time was an Electronics tec. when I was In the navy and have worked with electronics' a lot. If you search the archives Bob has posted pictures of the wiring set up that should cover what your looking for
Mark Taylor
PostPosted: Sun Apr 15, 2018 11:28 am    Post subject: Re: Converting to 12 volt Reply to specific post Reply with quote
[quote="CVPost-old"](reply to post at 10:26:07 04/15/1Cool [ok thanks I will try to find it as I am new and having some trouble with the forum navigation]
Mark Taylor
PostPosted: Sun Apr 15, 2018 12:53 pm    Post subject: Re: Converting to 12 volt Reply to specific post Reply with quote
Just need a little more help who is Bob and how do I find it in archive
old
PostPosted: Sun Apr 15, 2018 1:02 pm    Post subject: Re: Converting to 12 volt Reply to specific post Reply with quote
Bob is one of the people that have been on Y-T for years like my self. He has posted his diagram in the ford forums many times over the year. I cannot post a diagram my self but if it would help you can e-mail me and then I can give you my home number and maybe talk you threw how to wire it up
RaymondSmith
PostPosted: Mon Apr 16, 2018 3:39 am    Post subject: Re: Converting to 12 volt Reply to specific post Reply with quote
Nice thread... Very Happy
Post new topic    Yesterday's Tractors Forum Index -> Test Forum All times are GMT - 8 Hours
