john deere gt 275
BhB
PostPosted: Tue May 08, 2018 4:40 pm    Post subject: john deere gt 275 Reply to specific post Reply with quote
I have a John Deere GT 275 that is not charging the battery light stays on and only battery voltage when running. It worked last fall but not now. Any ideas of what to look for? Could be a mouse chewed the wires.
Bill
jeffcat
PostPosted: Wed May 09, 2018 6:07 am    Post subject: Re: john deere gt 275 Reply to specific post Reply with quote
Was in my friends repair shop just two days ago. JD sitting there nice and clean. Just as you describe. Check the wires going into your regulator. The two outer wires should read around 26-28 volts AC at about a good medium speed on throttle. Center terminal should read 14.2 volts DC with the other meter terminal going to ground. Measure at this point and then get back to us
jeffcat
PostPosted: Wed May 09, 2018 6:10 am    Post subject: Re: john deere gt 275 Reply to specific post Reply with quote
Wanted to leave this separate. Regulator could be bad or you popped the fuse. Do the tests first. Usually a yellow fuse.
gtractorfan
PostPosted: Wed May 09, 2018 5:19 pm    Post subject: Re: john deere gt 275 Reply to specific post Reply with quote
I have a JD 275 new in 1998, today it did exactly what yours does, the light came on, not charging, first problem I've had. Glad to see this topic brought up.
gtractorfan
PostPosted: Sat May 12, 2018 3:24 pm    Post subject: Re: john deere gt 275 Reply to specific post Reply with quote
I used the 275 today. I'd charged the battery, today when I started it the alternator light came on, then I revved the engine almost full throttle, never usually run near that fast. The light went off at high rev's, when I slowed it back down the light stayed off and stayed off the entire time I mowed, YIPPEE!
W_B
PostPosted: Fri May 18, 2018 4:36 am    Post subject: Re: john deere gt 275 Reply to specific post Reply with quote
CVPost-gtractorfan wrote:
(quoted from post at 00:24:19 05/13/1Cool I used the 275 today. I'd charged the battery, today when I started it the alternator light came on, then I revved the engine almost full throttle, never usually run near that fast. The light went off at high rev's, when I slowed it back down the light stayed off and stayed off the entire time I mowed, YIPPEE!
You should always run a hydro tractor at full throttle, keeps that fan going at max speed to cool the transmission and you have max power when you hit the high grass.
