John Deere 245 LG tractor
Richard W. Rocray
PostPosted: Fri May 18, 2018 5:55 am    Post subject: John Deere 245 LG tractor Reply to specific post Reply with quote
I need a useable main wiring harness for my 245 L&G tractor. The plug that goes to the rotary key
switch is shorted out on mine. I could use just a good plug because the remainder of the harness
is in good shape. Need a source for a used harness or just the plug, such as a tractor salvage yard
or new old stock parts warehouse. Thanks for any help in locating these parts.
steve_in_mo
PostPosted: Fri May 18, 2018 7:03 am    Post subject: Re: John Deere 245 LG tractor Reply to specific post Reply with quote
You can buy a good used wiring harmess for most JD equipment on eBay.
I have a couple sparesl, but they are for older garden tractors and not compatible with yours.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
There is the list of John Deere equipment that used the same switch. Easiest fix would be a good used switch with a good used plug and attached wires cut off at 3-4 inches.
Bob
PostPosted: Fri May 18, 2018 12:32 pm    Post subject: Re: John Deere 245 LG tractor Reply to specific post Reply with quote
This is one of the easiest requests that's showed up on here for a LONG time!
You can get a brand-new plug at your local DEERE dealership for about $1.68! The dealer I am set up with has 10 in stock, if your local dealer doesn't stock them, have them order one on a stock order, so you aren't stuck with a big freight bill.
A GOOGLE search will turn up dozens/hundreds of other sources, as well. GOOGLE "DEERE M90206".
You will need 5 wire terminals, as well, DEERE part number for those is U46662, @ about $0.55.
Or GOOGLE "Packard 56 series connectors".
ONE other source for the terminals
