Starting 670 LPG
herald h ia
PostPosted: Sun May 20, 2018 6:06 pm    Post subject: Starting 670 LPG Reply to specific post Reply with quote
I have a MM 670 Super LPG, and it will not start. It acts as it is not getting gas. If I give it a whiff of starting fluid, it will start right up. Question is , is there a value that opens on a suction of air when you hit the starter? Thanks for any help.
16-30 oilpull
PostPosted: Sun May 20, 2018 6:21 pm    Post subject: Re: Starting 670 LPG Reply to specific post Reply with quote
should have a primer button on the evaporator valve that acts like a choke. on my 706 or g1000 I hold it until I hear a bubble sound in breather. I assume 670 is set up same. Be sure you are starting on vapor. Can't really flood them, if you get to much in it will clear out after a little cranking.
mmfan55
PostPosted: Mon May 21, 2018 4:35 pm    Post subject: Re: Starting 670 LPG Reply to specific post Reply with quote
How long since last time it was run? I had one a while back that I had to disassemble regulator and carburetor and give both a thorough cleaning.
herald h ia
PostPosted: Mon May 21, 2018 7:24 pm    Post subject: Re: Starting 670 LPG Reply to specific post Reply with quote
this one has a choke like on a gas engine..It just seems that it has to have something that when you go to start it that something allows gas to get to the carb.It has Bosch fuel system.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
