won't start
steve19438
PostPosted: Wed May 23, 2018 10:14 am    Post subject: won't start Reply to specific post Reply with quote
my 1989 craftsman 2 has let me down. when I hit the key the solenoid thunks. not really a click more like snapping your fingers. battery is good. I replaced solenoid and new one does the same thing.
any ideas out there ???
Bob
PostPosted: Wed May 23, 2018 10:25 am    Post subject: Re: won't start Reply to specific post Reply with quote
Jab an old screwdriver between the large posts on the solenoid to bypass it and put battery power direct to the starter and see what happens.
Could be a failed starter or a engine grounding issue.
Also, can you turn the engine over normally by hand, thereby ruling out a starter drive jammed into the flywheel ring gear?
steve19438
PostPosted: Wed May 23, 2018 1:00 pm    Post subject: Re: won't start Reply to specific post Reply with quote
I tried jumping to starter with a battery pak. no good. will try the screw driver trick next. don't know yet about turning over eng. I have retired for the day. frustrated.
thanks.
Mule Meat
PostPosted: Wed May 23, 2018 9:14 pm    Post subject: Re: won't start Reply to specific post Reply with quote
Which engine does it have?
Briggs opposed twin cylinder or a Kohler?
steve19438
PostPosted: Thu May 24, 2018 12:58 am    Post subject: Re: won't start Reply to specific post Reply with quote
briggs
Mule Meat
PostPosted: Thu May 24, 2018 3:45 am    Post subject: Re: won't start Reply to specific post Reply with quote
CVPost-steve19438 wrote:
(quoted from post at 01:58:15 05/24/1Cool briggs
Ok.. You can buy a new starter for less than $30.
