cultivating with cub/140 - row width
wicomico160
PostPosted: Tue May 29, 2018 6:18 am    Post subject: cultivating with cub/140 - row width Reply to specific post Reply with quote
Can anyone tell me if I will be able to use a cub or IH 140 on 30" rows cultivating 1 row at a time - if not - can you make it so it straddles 2 rows and just reset the cultivating tines? Just doing this for sunflower - dove field - someone offering me a cub/140 and don't want to take it if won't work.
thanks.
Brendon-KS
PostPosted: Wed May 30, 2018 8:00 pm    Post subject: Re: cultivating with cub/140 - row width Reply to specific post Reply with quote
According to the Nebraska test report for the 140 the wheel spacing range is 44-70 and 40-68, front and rear respectively. When straddling one 30" row you'd only have 3 or 4 inches between the edges of the tires and the adjacent rows which isn't very much at all. I'd plan on setting both front and rear at 60" and straddle two rows.
The Cub's minimum wheel spacing is about the same as a 140 but the max is only about 56". This is still plenty close enough to the ideal 60" for straddling two 30" rows.
Traditional Farmer
PostPosted: Thu May 31, 2018 5:00 pm    Post subject: Re: cultivating with cub/140 - row width Reply to specific post Reply with quote
How do you cultivate with a 1 row cultivator while straddling two rows?
Brendon-KS
PostPosted: Thu May 31, 2018 6:47 pm    Post subject: Re: cultivating with cub/140 - row width Reply to specific post Reply with quote
You can still cultivate one row while straddling two - just turn around and drive right down the same path you just went to work the row that wasn't done on the first pass. The draft of a single row setup would be light enough that having the cultivator offset from the tractor centerline shouldn't cause a problem, especially with a 140.
Traditional Farmer
PostPosted: Fri Jun 01, 2018 4:34 am    Post subject: Re: cultivating with cub/140 - row width Reply to specific post Reply with quote
I can't see how it would work very well think he needs narrow tires and get it narrowed up as much as possible.
Post new topic    Yesterday's Tractors Forum Index -> Using Your Tractor & Crop Talk All times are GMT - 8 Hours
