1935 FTA oil filter
Goto page 1, 2  Next
moll
PostPosted: Tue May 29, 2018 6:39 am    Post subject: 1935 FTA oil filter Reply to specific post Reply with quote
Anybody have an idea where to get an oil filter for this model?
molinegb
PostPosted: Tue May 29, 2018 6:49 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
FTA would not have had a filter. Felt packing was filter originally. Updated was same as U or G Original number KE5905. Sock type are available.
moll
PostPosted: Tue May 29, 2018 7:19 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Thanks, how is the oil pressure adjusted? This has a filter housing like a KTA.
And how much pressure should it be running?
molinegb
PostPosted: Tue May 29, 2018 7:24 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Minimum 15 when hot if motor in decent shape.
moll
PostPosted: Tue May 29, 2018 7:32 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
That's kind of what I thought, mine is over oiling at 30 if the guage is correct.
How is the pressure adjusted?
molinegb
PostPosted: Tue May 29, 2018 7:41 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Pressure regulator screw on bottom of filter housing. 30 is a little high. I would set 30 cold. Motor must be in decent shape on bottom end.
moll
PostPosted: Tue May 29, 2018 8:09 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Thanks a lot for the help, its been bothering me for a couple of days and I hadn't been
able to get a plan together. The engine has great compression and ran really well before
that, I was planning on taking it to our show in August and then taking it down this winter
for inspection and repairs, seems like changing oil caused all this trouble and I think im
going to switch to non detergent oil also, just put in straight 30 weight Saturday.
moll
PostPosted: Tue May 29, 2018 8:46 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Something I forgot to mention, I had a few suggestions about the bottom end being worn, but if
it was badly worn wouldn't it be hard to get such high oil pressure? I'm tellin ya, it shoots
up out of the rockers like a water fountain at the park.
molinegb
PostPosted: Tue May 29, 2018 8:48 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Someone suggested hydraulic oil. U/KTA oil filter setup same. Basic. Thinking pressure too high thus knocking out your O ring. Blockage? Maybe take off filter housing and clean.
molinegb
PostPosted: Tue May 29, 2018 8:51 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Bypass valve stuck.
moll
PostPosted: Tue May 29, 2018 9:05 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Thanks, i'll take that housing clear off and disassemble it, see whats up hopefully.
Never ran into such a thing, but these are my first TC/M&M tractors, I really need to
get a manual.
1923 Gleaner
PostPosted: Tue May 29, 2018 6:26 pm    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
You can still get the canister oil filters from Baldwin. The one for the FTA is the same as a G so when you ask the retailer for the application just tell him a G Minnie. The KTA uses the smaller one like the U. I get them from Hampel in Wichita.
WGM
PostPosted: Fri Jun 01, 2018 11:18 am    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Non detergent oil should only be used to lubricate door hinges and has no place in an internal combustion engine.
1923 Gleaner
PostPosted: Fri Jun 01, 2018 3:33 pm    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
CVPost-wgm wrote:
(quoted from post at 21:18:56 06/01/1Cool Non detergent oil should only be used to lubricate door hinges and has no place in an internal combustion engine.
Wow Einstein, where were you 75 years ago.
I would never use detergent oil in an engine that has never had it used in it before. If Non detergent was good enough when the tractor was new it certainly is good enough now.
molinegb
PostPosted: Fri Jun 01, 2018 5:04 pm    Post subject: Re: 1935 FTA oil filter Reply to specific post Reply with quote
Non detergent oil was all that was ever used. If you change the motor will smoke and use oil. Less detergent in oil the better for Ford 6l diesels. Been there.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
