Farmall H Rear Steel on ZTU?
Ken Christopherson
PostPosted: Sat Jun 02, 2018 9:13 pm    Post subject: Farmall H Rear Steel on ZTU? Reply to specific post Reply with quote
Hello all! I have a question for you. I found a post in the archives where a fella put some F12/14 rear cutoffs on his ZTU... There was some discrepancy listed in the post (Link included below) as to whether or not the swap was attainable. The axles on a ZTU are 2 1/2", and I believe are the same on the IH H. F12/14 axles are 2 5/8", I believe, and are also double-keyed.
Question is, I have a guy just up the road from me with a set of IH H rear steel that I can pick up, and since the rear rims on my ZTU are too far rotted to save, I figured this would be a good temporary fix (plus they actually look pretty neat). Besides that, I also have a '42 IH H that came on steel from the factory that I could return to steel if I ever had the desire. Essentially, these would be a good fit (if they fit) to get me by for a while - as I could probably go for a rear tire replacement on the ZTU as well.. So rims and tires for that tractor, easily, will put me over $1500... Where, I can get these steel wheels for a mere fraction of that.
Anyone have any thoughts or info on this? I plan on measuring my H and ZTU axles when I get home from work in the morning, but just thought I would pick everyone's brain on the subject.
Any help is greatly appreciated!
Original ZTU F12/14 Steel Cutoff Post
T.R.K.
PostPosted: Sun Jun 03, 2018 4:29 am    Post subject: Re: Farmall H Rear Steel on ZTU? Reply to specific post Reply with quote
I can't tell you which farmall wheel fits, but I have seen a ZA on Farmall rear steel wheels and have seen pictures of two or three others. Since you know where a set is, measure them and measure your axle.
MIKE FRENCH
PostPosted: Tue Jun 05, 2018 10:21 am    Post subject: Re: Farmall H Rear Steel on ZTU? Reply to specific post Reply with quote
yes H steel will fit your axle, only thing is the H steel doesnt have as thick of key but will work
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
