Allis C Magneto With NO Spark
bisenberger
PostPosted: Sat Jun 09, 2018 5:15 pm    Post subject: Allis C Magneto With NO Spark Reply to specific post Reply with quote
What is the best way to test the condensor on a Fairbanks Morse magneto on an Allis Chalmer C?
What is the best way to test the coil on a Fairbanks Morse magneto on an Allis Chalmer C?
What other test would be appropriate?
Ted in NE-OH
PostPosted: Sat Jun 09, 2018 5:44 pm    Post subject: Re: Allis C Magneto With NO Spark Reply to specific post Reply with quote
First thing to do is drag a piece of rough paper through the points, that fixed a lot of them, and is a common cause of no spark.
teddy52food
PostPosted: Sat Jun 09, 2018 7:06 pm    Post subject: Re: Allis C Magneto With NO Spark Reply to specific post Reply with quote
I have a coil and condenser tester to check them. Also have a just like new mag on the shelf if you need it. I am in mid Mn. Where are you?
old
PostPosted: Sun Jun 10, 2018 8:17 am    Post subject: Re: Allis C Magneto With NO Spark Reply to specific post Reply with quote
As on anything with points you stand a 90% chance the points are the problem when you do not have spark. Condensers do not go bad out of the clear blue and coils while they do go bad most of the time you can see oddity's in them when they go bad
Dick L
PostPosted: Sun Jun 10, 2018 9:27 am    Post subject: Re: Allis C Magneto With NO Spark Reply to specific post Reply with quote
If you have a black tape covered coil it could be the problem. If it is a red plastic coil it most likely is good. I just changed out a black taped one with a red one myself. As stated points get a coating on the pads that keep them grounding out to spark.
tractorguy2
PostPosted: Sun Jun 10, 2018 12:07 pm    Post subject: Re: Allis C Magneto With NO Spark Reply to specific post Reply with quote
You need to start by cleaning the points. If the condenser is bad. You will have fire at the points but not through the coil. Fairbanks magneto seen to have more bad coils than other brands.
There is a guy on ebay selling FM coils for Mercury outboard motors. They are much cheaper. I have used three of them with no trouble.
bisenberger
PostPosted: Thu Jun 14, 2018 2:18 pm    Post subject: Re: Allis C Magneto With NO Spark Reply to specific post Reply with quote
bisenberger wrote:
(quoted from post at 18:15:50 06/09/1Cool What is the best way to test the condensor on a Fairbanks Morse magneto on an Allis Chalmer C?
Thanks everyone for the suggestions.
Turns out the condenser was bad. I replaced it, now I have spark and my tractor runs as sweet as a 73 year old can
chaskaduo
PostPosted: Thu Jun 14, 2018 3:45 pm    Post subject: Re: Allis C Magneto With NO Spark Reply to specific post Reply with quote
Could you elaborate more on the FM coils for Mercury outboard motors.
