Author |
Message |
DougieD New User
Posted: Mon Jun 11, 2018 1:00 pm Post subject: What is this, and what does it do? |
I've looked in my service manual and my operator's manual, and can't find anything about this. What is this? At first I thought Paul Bunyan comb, but now I'm thinking no. And what does it do? And where should I put it? Thanks.
Back to top |
Charlie M Tractor Guru
Posted: Mon Jun 11, 2018 1:38 pm Post subject: Re: What is this, and what does it do? |
I believe that adjusted the 2 point hitch on the 300, 350, 400, 450 tractors but I'm not sure exactly what it adjusted. I think it moved the hitch for traction control but maybe draft for mounted plows. I'm
sure there are others that won't be guessing. |
Back to top |
the tractor vet Tractor Guru
Posted: Mon Jun 11, 2018 4:33 pm Post subject: Re: What is this, and what does it do? |
It is what they called a TRACTION BOOSTER and some what of a draft control . You use it when pulling a fast hitch implement and it transfers the draft to add more of the pulling weight to the rear tires , For normal use you set it down to the last notch. If you notice you have tomuch wheel slip then you start to bring it up a notch at a time till you get the desired traction . When i had my 450D and pulling the semi mounts i usually ran it around two notches from the top or up possession , now one musdt watch as in hilol country she will lift the ft. easy going up the hills . |
Back to top |
DougieD New User
Posted: Mon Jun 11, 2018 4:51 pm Post subject: Re: What is this, and what does it do? |
Imsee. Thanks. So the higher the handle, the more traction. |
Back to top |
BarnyardEngineering Tractor Guru
Posted: Tue Jun 12, 2018 3:26 am Post subject: Re: What is this, and what does it do? |
You got lucky this time but next time please include the model of tractor that you're asking about.
It may still be useful in this case. The reason your manual may not go into the operation of the traction/draft control lever is because the hitch may not belong on that tractor. There were multiple designs for the fast hitch during the short time it was produced. Tractors made in 54-56 had a different style from tractors made in 57-62, and it changed yet again in 63. |
Back to top |
Mark (EC,IN) Regular
Posted: Tue Jun 12, 2018 2:35 pm Post subject: Re: What is this, and what does it do? |
I think the reason you didn't find it in the tractors operators manual is that it had a
manual of its own. |
Back to top |
Eastsider Regular
Posted: Tue Jun 12, 2018 6:38 pm Post subject: Re: What is this, and what does it do? |
When you have an extra one, they make a great custom anchor handle for a river anchor!
Back to top |
DougieD New User
Posted: Tue Jun 12, 2018 6:43 pm Post subject: Re: What is this, and what does it do? |
Good to know! |
Back to top |
