Bolt grade for Farmall H rear rim clamp bolts
BarnyardEngineering
PostPosted: Tue Jun 12, 2018 3:53 am    Post subject: Bolt grade for Farmall H rear rim clamp bolts Reply to specific post Reply with quote
Burnt up an entire set of drill bits and really tested my Craftsman 1/2" ratchet, but I got that %$#@ boogered up rim clamp bolt out of my H yesterday. It's been like that for a long time, but lately it has been really annoying me, so glad it's out. Paint damage is minimal. A little JB weld to cover up where I nicked the cast with the cutoff wheel, and a spritz with a spray bomb, and it will be good as new.
Next challenge is to find the clamp Dad bought for it. I think I know where it is, but it's going to involve a lot of digging...
Now to go back in, should I use a Grade 5 bolt? Parts book only calls for 5/8-11 x 4-1/4. No grade mentioned. Ordering from Mcmaster.
DR. EVIL
PostPosted: Tue Jun 12, 2018 4:01 am    Post subject: Re: Bolt grade for Farmall H rear rim clamp bolts Reply to specific post Reply with quote
A grd 5 should be good enough. Think you are replacing an IH Dot head bolt in those rims, they for sure
were more than a grade #2.
BarnyardEngineering
PostPosted: Tue Jun 12, 2018 4:11 am    Post subject: Re: Bolt grade for Farmall H rear rim clamp bolts Reply to specific post Reply with quote
Yeah, it was a dot head bolt before I drilled it out. Had to drill from both ends because the bolt would heat harden on me at about 2" deep.
rustyfarmall
PostPosted: Tue Jun 12, 2018 4:53 am    Post subject: Re: Bolt grade for Farmall H rear rim clamp bolts Reply to specific post Reply with quote
Grade 5 will be just fine.
fastfarmall
PostPosted: Tue Jun 12, 2018 6:34 pm    Post subject: Re: Bolt grade for Farmall H rear rim clamp bolts Reply to specific post Reply with quote
Be careful on the first nut, that one strips pretty easy,It's pretty narrow.
