John Deere, model 44, rope pull plow
Dwight Tuttle
PostPosted: Tue Jun 12, 2018 9:05 pm    Post subject: John Deere, model 44, rope pull plow Reply to specific post Reply with quote
I'm trying to remove the left wheel [clutch side] from the axle.
I removed the cap, I removed the pin from the axle. The wheel will
slide a little bit on the axle, but will not come past the edge of
the axle. It feels like something is holding the wheel on the axle.
The three bolts are loose. Also, if anyone has a manual, that they
would be willing to sell, please let me know.
Thanks, Dwight
ET
PostPosted: Wed Jun 13, 2018 4:07 am    Post subject: Re: John Deere, model 44, rope pull plow Reply to specific post Reply with quote
The wheel is a tapper press fit onto the hub. You need to rig a puller to get the wheel off the hub.
David from Kansas
PostPosted: Wed Jun 13, 2018 4:23 am    Post subject: Re: John Deere, model 44, rope pull plow Reply to specific post Reply with quote
Tyler the plow guy has a video on youtube. Type in "John Deere plow enclosed clutch".
JDBRIDER
PostPosted: Wed Jun 13, 2018 6:13 pm    Post subject: Re: John Deere, model 44, rope pull plow Reply to specific post Reply with quote
Been a while since I had mine apart but I think that you have to remove the nuts from the bolts. Then the wheel will come off. Then the piece behind needs to be turned maybe 1/4 turn to remove it.
Dwight Tuttle
PostPosted: Wed Jun 13, 2018 10:57 pm    Post subject: Re: John Deere, model 44, rope pull plow Reply to specific post Reply with quote
I can use a puller, to get the wheel off. Then what do I need to put the wheel, back on the axle?
Leroy
PostPosted: Thu Jun 14, 2018 4:29 am    Post subject: Re: John Deere, model 44, rope pull plow Reply to specific post Reply with quote
Just clean and enough anti seize to cover to help in dissembly again years later and assemble and bolts will tighten it up
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
