Mack cooling system hose alert
showcrop
PostPosted: Wed Jun 27, 2018 7:44 am    Post subject: Mack cooling system hose alert Reply to specific post Reply with quote
Three weeks ago I posted about a fitting and hose problem on a 2013 Mack. Today I got a call from the truck owner asking me to go out and rescue one of the other drivers on the side of the road with the same truck. This time it was a connector hose in the lines to the transmission cooler. The original hose was silicone as was the replacement. The truck has only 125,000 miles, but these hoses carry a lot of volume of very hot coolant.
caterpillar guy
PostPosted: Wed Jun 27, 2018 9:49 am    Post subject: Re: Mack cooling system hose alert Reply to specific post Reply with quote
You do have to be careful not to over tighten the clamps on those. The hose is really soft and will cut from the squeezing force of the clamp as it is tightened thus causing a failure.
I did that on one one time, how I know. Otherwise it should handle any temperature the engine is running.
This is on the silicone hose.
MikeJM
PostPosted: Wed Jul 04, 2018 10:13 am    Post subject: Re: Mack cooling system hose alert Reply to specific post Reply with quote
Silicone hose is fantastic for many things, but proper clamping is critical. Worm style clamps must be lined or it will extrude through the hose clamp. And like caterpillar guy said, don’t over tighten.
showcrop
PostPosted: Wed Jul 04, 2018 4:55 pm    Post subject: Re: Mack cooling system hose alert Reply to specific post Reply with quote
There was no damage at the clamps or leaking from the ends of the hose. Only a three inch long tear.
ohiodick
PostPosted: Thu Jul 05, 2018 8:45 pm    Post subject: Re: Mack cooling system hose alert Reply to specific post Reply with quote
does it have an allison trans.
showcrop
PostPosted: Fri Jul 06, 2018 3:17 am    Post subject: Re: Mack cooling system hose alert Reply to specific post Reply with quote
CVPost-ohiodick wrote:
(quoted from post at 21:45:37 07/05/1Cool does it have an allison trans.
Yes, it does. As I said in the OP it was in the pressure line to the cooler.
ohiodick
PostPosted: Sat Jul 07, 2018 7:01 pm    Post subject: Re: Mack cooling system hose alert Reply to specific post Reply with quote
green or red hose there was a change in material. green is later hose.
showcrop
PostPosted: Sun Jul 08, 2018 3:12 am    Post subject: Re: Mack cooling system hose alert Reply to specific post Reply with quote
(quoted from post at 20:01:30 07/07/1Cool green or red hose there was a change in material. green is later hose.
It was the later hose.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
