G1350 Injection timing
f5erg7g6
PostPosted: Thu Jul 05, 2018 9:13 am    Post subject: G1350 Injection timing Reply to specific post Reply with quote
Finally got tired of leaks and always needing to prime our old 1350, so I decided to spend some money on the fuel system (new
injectors, rebuild pump) When i was going to put the pump back on the other day, I look in the book to get the static timing,
and i was perplexed to find it is factor at 4 degrees ATDC. I figured it would be at 10-15 degrees BTDC. MY main question is, is
4 degrees in fact correct and should i set the pump there or give it more timing? Thanks. Any input/knowledge would be good.
molinegb
PostPosted: Thu Jul 05, 2018 10:03 am    Post subject: Re: G1350 Injection timing Reply to specific post Reply with quote
Only motor that MM made that fires after TDC.
Bob
PostPosted: Thu Jul 05, 2018 9:35 pm    Post subject: Re: G1350 Injection timing Reply to specific post Reply with quote
Must be a "timed injection end" setup.
Dieseltech
PostPosted: Fri Jul 06, 2018 6:04 pm    Post subject: Re: G1350 Injection timing Reply to specific post Reply with quote
Pumps can be timed beginning of injection, OR end of injection like most Stanadyne/Roosa-Master pumps are. End of injection is used most on IH, JD, Oliver, Case, and MM engines with Roosa pumps. AC, MF, Perkins Commonly use beginning of injection pumps.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
