John Deere 567 baler issues
jwr_03
PostPosted: Fri Jul 13, 2018 4:54 am    Post subject: John Deere 567 baler issues Reply to specific post Reply with quote
My neighbor has does my baling for me. He has a John Deere 567 mega wide, silage special baler with cover edge wrap. Yesterday was the first time he had to change the net wrap. The baler worked fine before we changed rolls. Now we are having problems with net wrap wrapping properly. He wasn't wrapping at all. I think this was because we hadn't threaded the wrap correctly. Then we tried one more bale before dark and it made a big rip in the wrap and the bale was busting out. What could be the cause of this?? Does cover edge need the plastic spacers in the ends of the rolls??
Tx Jim
PostPosted: Fri Jul 13, 2018 9:04 am    Post subject: Re: John Deere 567 baler issues Reply to specific post Reply with quote
Need more info but my 1st guess is netwrap is routed incorrectly. Buildup of hay between netwrap attachment & forming belts can cause tear in netwrap on bale. What type hay are you attempting to bale.
KYpatriot
PostPosted: Fri Jul 13, 2018 9:53 am    Post subject: Re: John Deere 567 baler issues Reply to specific post Reply with quote
Go online and look at this:
https://m.youtube.com/watch?v=jeXZ8OzFa80
Also, on a new roll, it helps for some reason to put some baby powder on the rubber roller. You only have to do it once when loading new wrap or if the roller got wet/really damp.
I had tons of problems with netwrap on another brand baler, but the john deere netwrap system works really well with few problems if you load it correctly.
Tx Jim
PostPosted: Fri Jul 13, 2018 10:53 am    Post subject: Re: John Deere 567 baler issues Reply to specific post Reply with quote
I haven't put powder on my JD 467 netwrap rubber feed roller in several yrs. IMHO if netwrap isn't wrapping rubber roller powder is a waste of $$$$$
JD Seller
PostPosted: Fri Jul 13, 2018 7:06 pm    Post subject: Re: John Deere 567 baler issues Reply to specific post Reply with quote
I will second the thought that he has it threaded wrong. There should be a decal right in the rear when mesh wrap door is open, showing the correct way to thread the baler. While your checking this out also pull 10 foot or so of the mesh of the new roll. I have gotten two bad rolls this year. They would not pull smoothly on the one, it pulled two hard. The other was wrapped in such away it tore as it was feeding. So make sure the mesh comes off the roll evenly and does not catch.
rockyridgefarm
PostPosted: Fri Jul 13, 2018 7:35 pm    Post subject: Re: John Deere 567 baler issues Reply to specific post Reply with quote
Are you using good quality net wrap? I just bought a 469, but before that, I had a Vermeer. I didn't have a lick of trouble with Vermeer wrap, but had loads of trouble when I used some "other" brand wrap bought for the hardware store in town.
