TR98 NH COMBINE CHAFF SPREADER INSTALL
Goto page Previous  1, 2
Milk
PostPosted: Tue Aug 14, 2018 4:19 am    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
Thanks for the advice I got the chaff
spreader hooked up yesterday. Seems to work
the way that its supposed to. All is well
so far!!
dbock
PostPosted: Wed Sep 12, 2018 2:32 pm    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
Milk, did you get your beater replaced? We are having a hard time getting ours out. I have some questions if you have gotten yours out.
Milk
PostPosted: Wed Sep 12, 2018 6:42 pm    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
so sorry for the late reply. what I did was to bolt on to the discharge beater fins 4" pieces of notched metal,4 of them for each fin,they have to be balanced equally.I staggered each 4" notched piece so as when the beater fins make a revolution, they have more grabbing power to pull the material coming out of the rotors. Haven't used it yet but I think that it's going to work!! I looked at the beater and decided that there was too much stuff to dissemble, way too much work!!! I got this idea from looking at the website from the company in south Dakota that specializes in retrofitting replacement parts for different makes of combines.
dbock
PostPosted: Sat Sep 15, 2018 4:13 am    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
Thanks for the reply. After a lot of heat and a few choice words, we finally got the beater out. I wasn't sure how the beater attached to the shaft, but the shaft has a tapered spline on one end. Our beater was to beat up to repair, so we are going with the the one from ND. We had to send them the hubs off of our beater, so it will be 10 days before we get it.
Milk
PostPosted: Sat Sep 15, 2018 10:40 am    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
That's great!looks like a great retrofit. Are you changing out the bearings also?Its a little too spendy for me but I think that it's going to be better than new!
I got the chaff spreader working great but the reel turns over very slowly, can't make it go any faster than a slow turn!!Any suggestions are greatly appreciated!!
Milk
PostPosted: Sat Sep 15, 2018 11:41 am    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
Does anyone here on this forum have any suggestions on how to get the reel to turn on my TR98 NH combine? Last year it was would slow down and stop for no apparent reason! the control knob in the cab just spins without feeling any pressure when turning it, not much control for the reel, but some control is there!
Only thing different I did this year was to add a chaff spreader!The machine already has a binfil extender! Maybe too many hydraulic hookups for reel pump!!!!
dbock
PostPosted: Sat Sep 15, 2018 4:53 pm    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
Are the bin extension auger and the chaff spreader turning alright? If the system was overloaded then it would probably slip the belt that drives the reel pump on the right side of the combine. You might check to see if that belt is tight. It might also be in the valve or the reel speed controller. I think there is a way to set the valve manually, but I'm not sure how.
Milk
PostPosted: Sat Sep 15, 2018 7:04 pm    Post subject: Re: TR98 NH COMBINE CHAFF SPREADER INSTALL Reply to specific post Reply with quote
everything turns at valved controlled speeds. Not much pressure on the port where the hydraulic hook for the reel speed hydraulic is located. Tried adjusting the valve to override the cab controller located under the platform, but can't seem to move it after loosen the nut! might have to call in the mechanic!!
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
Page 2 of 2
