Min Painting Temp
Formerly PaMike
PostPosted: Fri Mar 02, 2007 9:33 am    Post subject: Min Painting Temp Reply to specific post Reply with quote
I am spraying some U-Tech 3.8 Polyurathane. Its a 2 part paint. I sprayed all the small parts at work in the booth, but now I need to do the base tractor. I called the tech line and the minimum temp for painting they would recommend is 60 degrees. What temperatures have you guys sprayed at?Thanks
Greg 77
PostPosted: Fri Mar 02, 2007 12:47 pm    Post subject: Re: Min Painting Temp Reply to specific post Reply with quote
The lower the temperature the higher the risk of getting runs in your paint. Recoat timing is harder to calculate also. If you want do do a good error free job with no headaches, 60 degrees is the minimum temperature I would spray at.
djw
PostPosted: Fri Mar 02, 2007 5:58 pm    Post subject: Re: Min Painting Temp Reply to specific post Reply with quote
Hi Mike, I paint a few tractors every winter in
my garage. I have a torpedo heater and
pretty much heat the tractor up till its hot to
touch. No runs yet , and they turn out decent.
Dave
CNKS
PostPosted: Fri Mar 02, 2007 6:08 pm    Post subject: Re: Min Painting Temp Reply to specific post Reply with quote
65
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
