gas tankcleaning
jr150hp
Guest
PostPosted: Tue Mar 06, 2007 5:26 pm    Post subject: gas tankcleaning Reply to specific post Reply with quote
i fixed the sending unit on my 841 ford before i put the sender back in i happened to put my finger in the tank and felt it was rough and rusted inside . It seemed to be just on the topside the tractor ran great the fuel bowl show just a little bit of rust on the screen. is there a way to seal the rust in the tank or do i need to boil it and get the rust all out of it which i don't know how to do . i see there is some paint coatings you can put right on the rust anyone ever have sucess with this stuff if so whats the name of the product or should i not worry about it she's not a trailer queen i do work her fairly hard plowing and dicsing 7 acres a year takeing off hay and picking and spreading manure thanks JR.
GlenIdaho
Guest
PostPosted: Tue Mar 06, 2007 9:10 pm    Post subject: Re: gas tankcleaning Reply to specific post Reply with quote
Jr.; There are several products on the market to clean and seal fuel tanks. I used U.S. Standard Fuel tank sealer and Metal Ready from Por 15. The Metal Ready will clean the tank as I believe it is a phosphoric acid. Once the tank is clean and dry you pour in a quart of the sealer and slosh it around and then let is drain. It applies a relatively thick coating of sealer on the inside of the tank. For more info on the product you can check out "Por 15" on the internet.
There are some radiator shops that will seal the tank for you. To do it myself it was a relatively easy process, just time consuming.
As far as worrying about it, it really depends on how bad the rust is. One thing you don't want to happen is a fire due to gas leaking on a hot manifold, etc. My tank didn't leak but like you I found rust inside and in some spots the metal appeared thinner than others. To be on the safe side I sealed the tank. Hope this helps.
jr150hp
Guest
PostPosted: Wed Mar 07, 2007 7:16 am    Post subject: Re: gas tankcleaning Reply to specific post Reply with quote
thanks your right safety first
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
