what is best grease for babbitt bearings?
derwen1959
PostPosted: Wed Aug 29, 2018 7:36 am    Post subject: what is best grease for babbitt bearings? Reply to specific post Reply with quote
what is the best grease for the big end and main babbitt bearings on my 1920's Amanco engine
Richard G.
PostPosted: Wed Aug 29, 2018 10:33 am    Post subject: Re: what is best grease for babbitt bearings? Reply to specific post Reply with quote
I would use just grade 2 tractor type grease or maybe wheel bearing grease.
Just make sure you grease it often without putting too much grease.
Richard in NW SC
Pete in Holland MI
Some generic wheel bearing style grease in a can is all you need. Don't sweat the details. Most anything you put in there is far better than what was available 80 years ago.
Destroked 450
PostPosted: Wed Aug 29, 2018 1:34 pm    Post subject: Re: what is best grease for babbitt bearings? Reply to specific post Reply with quote
We had a lot of rabbit bearings at the local mill I worked at.
In hot weather we used ep2 grease, in cold weather we switched to ep1 because it was easier to pump into the bearings.
In hot weather ep1 didn't stay on the bearings long.
Destroked 450
PostPosted: Wed Aug 29, 2018 1:38 pm    Post subject: Re: what is best grease for babbitt bearings? Reply to specific post Reply with quote
I thought those engine had oilers for the bearings and used some type of motor oil.
derwen1959
PostPosted: Thu Aug 30, 2018 2:42 am    Post subject: Re: what is best grease for babbitt bearings? Reply to specific post Reply with quote
hello Destroked 450
thanks for reply, I have seen oilers for lubricating bearings , but this one has grease cups and it has not been converted to high tension ignition... I am in UK
derwen1959
PostPosted: Thu Aug 30, 2018 2:49 am    Post subject: Re: what is best grease for babbitt bearings? Reply to specific post Reply with quote
I should have said thanks for all replies... I now know what grease to use .. I want to make a frame so it is fixed onto axle and put curtain sides around it
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
