John Deere GT225
Averie
PostPosted: Fri Sep 14, 2018 5:32 pm    Post subject: John Deere GT225 Reply to specific post Reply with quote
I am looking to remove the engine from this John Deere GT225 garden tractor. I will have to remove the belt and the PTO from the crankshaft. I have removed the bolt from bottom but it did not come off. What else could be holding this on??? or what attempt do I use to get the PTO and the drive pully off any tips would be appreciated.
Lance Skene
PostPosted: Sat Sep 15, 2018 10:25 am    Post subject: Re: John Deere GT225 Reply to specific post Reply with quote
The bolt in the end of the crank should release the pto but it might be rusted on, and sometimes belt guards/guides can get in the way. Penetrating fluid and LIGHT prying should do... may need a gear/pulley puller.
steve_in_mo
PostPosted: Sat Sep 15, 2018 1:16 pm    Post subject: Re: John Deere GT225 Reply to specific post Reply with quote
Prying is probably not a good idea on a pressed steel pulley.
Penetrant, mild heat, and a puller are better bets.
Lance Skene
PostPosted: Sat Sep 15, 2018 1:38 pm    Post subject: Re: John Deere GT225 Reply to specific post Reply with quote
Note I said pry LIGHTLY.... the pto is not pressed on so it should have literally fallen off when the crankcase bolt was removed and you do not want to be heating up an expensive pto unit.... penetrating fluid and pry LIGHTLY
Lance Skene
PostPosted: Sat Sep 15, 2018 1:47 pm    Post subject: Re: John Deere GT225 Reply to specific post Reply with quote
Sry.... CrankSHAFT bolt... not crankcase
