Widen rims
WFE270NWIA
PostPosted: Sun Sep 16, 2018 5:29 am    Post subject: Widen rims Reply to specific post Reply with quote
Need to widen some rims for 15.5 X 38 tires. Would you go to 15 or 16 inches? Weld the bands on both the inside and the out side? Thinking of making the bands out of 12 ga. Anyone happen to know how the bands need to be for 38 inch rims? Thanks.
WFE270NWIA
PostPosted: Sun Sep 16, 2018 5:32 am    Post subject: Re: Widen rims Reply to specific post Reply with quote
Last question should be how long do bands need to be for 38 inch rims. Thanks.
mmfan55
Spacer rings off duals work good
Gary Mitchell
PostPosted: Sun Sep 16, 2018 7:06 am    Post subject: Re: Widen rims Reply to specific post Reply with quote
They need to be 3.141 X the diameter at the point of the rim where you're splitting it. gm
View user's profile AIM Address
D beatty
PostPosted: Sun Sep 16, 2018 10:24 am    Post subject: Re: Widen rims Reply to specific post Reply with quote
What size rim do you have now? I have 15.5x 38 on 14' rims and that's what they recommend for 15.5x38 tires.
WFE270NWIA
PostPosted: Sun Sep 16, 2018 1:38 pm    Post subject: Re: Widen rims Reply to specific post Reply with quote
I haven't dug the rims out of the "junk pile" yet. They are drop center rims off a U MM so I would guess they are 11" or 12" wide. The 15.5 are on pressed steel rims, not sure how wide they are.
Dblair
PostPosted: Sun Sep 16, 2018 3:47 pm    Post subject: Re: Widen rims Reply to specific post Reply with quote
most welded rims are banned at most pulls I've been to .
showcrop
PostPosted: Sun Sep 16, 2018 5:51 pm    Post subject: Re: Widen rims Reply to specific post Reply with quote
I go 16 unless there is a rule against. Conventional wisdom is when it is a little wider than the tire it holds the tire open a little wider.
WFE270NWIA
PostPosted: Sun Sep 16, 2018 6:22 pm    Post subject: Re: Widen rims Reply to specific post Reply with quote
No problem with that here.
mmfan55
PostPosted: Mon Sep 17, 2018 11:14 am    Post subject: Re: Widen rims Reply to specific post Reply with quote
Difference in attitude and mentally I guess. I don't remember being at any pull in the past 30 years that bans welded rims.
showcrop
PostPosted: Mon Sep 17, 2018 3:24 pm    Post subject: Re: Widen rims Reply to specific post Reply with quote
You can run into problems at the tire store though. I was getting tires changed on my Ford 9000 puller at the chain tire store one time and the wise-A** store manager walked by and asked the mechanic what was he doing working on welded rims? but kept on walking. One tire didn't want to seat and the mechanic took it to no more than 30 lbs and told me that I was on my own. That was OK. When I got home I dropped it to 5 lbs and drove it around a little and it popped in.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
