farmall h hole in carb
charlie (ky)
PostPosted: Thu Sep 20, 2018 5:03 am    Post subject: farmall h hole in carb Reply to specific post Reply with quote
What is the purpose of the small hole in bottom of carb?. I read somewhere it should have a piece of felt over or in it.
rustred
PostPosted: Thu Sep 20, 2018 5:34 am    Post subject: Re: farmall h hole in carb Reply to specific post Reply with quote
that is the gas drain when using the choke. its covered to keep dirt from being sucked in.
rustyfarmall
PostPosted: Thu Sep 20, 2018 5:49 am    Post subject: Re: farmall h hole in carb Reply to specific post Reply with quote
It is to allow condensation to escape. Otherwise the water would just accumulate in the bottom of the carb and then be drawn into the engine. Yes, there should a filter of some sort in that hole. Original filter was made of felt. There is also supposed to be a steel welch plug to hold the filter in place. The welch plug will have a small hole in the center.
charlie (ky)
PostPosted: Thu Sep 20, 2018 12:31 pm    Post subject: Re: farmall h hole in carb Reply to specific post Reply with quote
At last , something I can under stand and probably fix. :) Thanks Rustred and rustyfarmall
