MM RTA
Patsdeere
PostPosted: Wed Sep 26, 2018 10:04 pm    Post subject: MM RTA Reply to specific post Reply with quote
So I came across a RTA as the seller says. I haven't found much reference to it anywhere. Was there an RTA? Anything special about it? If no RTA, then what might it be?
Thank you.
DIM
PostPosted: Thu Sep 27, 2018 3:24 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
Looks like a RTI 1948 or newer. Industrial model
MMDEL
PostPosted: Thu Sep 27, 2018 6:10 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
Could you post a clearer picture of the left side. It is a basic RTI but it looks like it has something going on on the left, like possibly hydraulic valve lifters like the military unit.
MMDEL
Butch...Mn
PostPosted: Thu Sep 27, 2018 7:57 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
mmdel makes a good point, but I am curious what the casting number on the head is also. RTI's typically have a 2648 head versus the more common 226C.
Patsdeere
PostPosted: Thu Sep 27, 2018 12:21 pm    Post subject: Re: MM RTA Reply to specific post Reply with quote
Don't know if this is any better.
DIM
PostPosted: Thu Sep 27, 2018 4:01 pm    Post subject: Re: MM RTA Reply to specific post Reply with quote
I see a brass tag under the gas tank. Maybe a military tractor
molinegb
PostPosted: Fri Sep 28, 2018 7:58 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
Doesn't have normal oil filter canister. Has add on one plumbed in. Has cam driven hydraulic pump.
BMG1
PostPosted: Fri Sep 28, 2018 8:04 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
RTIM or one of a few RTI built for the military before the RTIM. We have one just like it with the brass tags and lifting eyes. Pretty desirable tractor to the collector market.
MMDEL
PostPosted: Fri Sep 28, 2018 9:00 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
No hydraulic lifters. Looks like someone has added the engine oil hydraulic pump. Not for sure what you have there, but it is all MM. Even though MM didn't make the oil filter. It is the one they used on the Uni s.
MMDEL
ksmms
PostPosted: Fri Sep 28, 2018 2:59 pm    Post subject: Re: MM RTA Reply to specific post Reply with quote
looks like the same setup as my ZASI. in the book the same way. maybe parts from ZASI or came from factory that way
View user's profile AIM Address
ksmms
PostPosted: Fri Sep 28, 2018 3:02 pm    Post subject: Re: MM RTA Reply to specific post Reply with quote
MMDEL
PostPosted: Sat Sep 29, 2018 7:01 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
What exactly are all the numbers on all of the tags. The one on the right side of the engine, the one you say is under the fuel tank, and the one on the right side of the tran-diferential case. This should help a lot of wasted time guessing.
MMDEL
BMG1
PostPosted: Sun Sep 30, 2018 7:07 am    Post subject: Re: MM RTA Reply to specific post Reply with quote
The oil filter is military spec from MM. All RTIM were equipped that way. There's no filter canister on the pump.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
