ID an AC plow?
jCarroll
PostPosted: Tue Oct 02, 2018 8:43 am    Post subject: ID an AC plow? Reply to specific post Reply with quote
I recently acquired a 3-14 semi-mounted moldboard plow.
The remaining paint is AC orange, and it has the long, hitch loop so I assume it's an AC.
But can someone confirm, and maybe put a model number on it?
309244 is stamped on the back of each moldboard.
NO. 124-14 RH is stenciled on the back of each moldboard.
332810 is the casting number on the coulter hub which has the zerk.
Thx for your help.
(Sorry I don't know how to post photos)
Skyhighballoon(MO)
PostPosted: Tue Oct 02, 2018 11:13 am    Post subject: Re: ID an AC plow? Reply to specific post Reply with quote
Are the shanks vertical (not slanted forward) for the bottoms? If so and with the much older 124 bottoms, it's very likely to be a Model 53 plow, sometimes known as a WD pickup plow. Finding replacement shares/shins that bolt right up will be next to impossible for those 124 bottoms. About the only thing left available wear parts wise for Allis plows is for the much newer 387 bottoms. You might be able to re-drill your frogs for another share that is close to yours. Mike
BushogPapa
PostPosted: Mon Oct 08, 2018 6:34 am    Post subject: Re: ID an AC plow? Reply to specific post Reply with quote
If it has a long "Hitch Loop, I think that says it is for a later "Snap- Coupler"..(WD-45?).
Otherwise it will have the old cross-pin Hitch that nobody should use..(Convert it)..!!
