570 clutch
57fargo
PostPosted: Wed Oct 03, 2018 5:49 am    Post subject: 570 clutch Reply to specific post Reply with quote
I have a 570 Cockshutt diesel that the clutch all of a sudden stopped working, as in tractor does not move anymore. Anything besides needed a new clutch that would cause this? Does it need to be split to acces the clutch? Thanks in advance!
mach12
PostPosted: Wed Oct 03, 2018 8:21 pm    Post subject: Re: 570 clutch Reply to specific post Reply with quote
It?s not likely to be anything other than the clutch. Removing the cover is easy and the problem should be evident.
You don?t need to split the tractor, but you do need to pull the engine.
J. Schwiebert
PostPosted: Thu Oct 04, 2018 9:59 am    Post subject: Re: 570 clutch Reply to specific post Reply with quote
If I remember correctly the clutch hub had dampner springs and no doubt have failed as was mentioned so a new clutch is needed.
Irvb
PostPosted: Sat Oct 06, 2018 3:54 pm    Post subject: Re: 570 clutch Reply to specific post Reply with quote
Most likely the clutch disk but I have seen the splines on the input shaft rolled out and spun smooth. I would suggest you look over the tractor as in my opinion it is far easier to split the tractor in half and slide it apart about 6 inches. I can also help you with parts if you want help. If you have questions just email me. Irv
