M pto gasket
fred kobs
PostPosted: Wed Oct 03, 2018 6:08 pm    Post subject: M pto gasket Reply to specific post Reply with quote
Hey guys, was hoping somebody had a to scale picture of the gasket that goes in front? back? of the pto seal/bearing retainer. Just flushed the rear and filled with new, expensive gear lube. naturally in the dark corner of the shop after i installed the new pto seal i got the housing upside down. went to flip it and tore the gasket. now i need to replace the gasket and can't watch $ run out of it whle i cut a gasket. Thanks in advance for any help. and if you find this funny, please dont share, i will also probably chuckle about it later, much later. thanks again. Fred
rustred
PostPosted: Wed Oct 03, 2018 6:11 pm    Post subject: Re: M pto gasket Reply to specific post Reply with quote
whats wrong with draining the oil into a clean pail or pails? then make a gasket.
DeltaRed
PostPosted: Wed Oct 03, 2018 6:18 pm    Post subject: Re: M pto gasket Reply to specific post Reply with quote
My thoughts exactly.....
scott mcintosh
PostPosted: Wed Oct 03, 2018 6:35 pm    Post subject: Re: M pto gasket Reply to specific post Reply with quote
Park tractor facing down hill then remove flange.Scott
fred kobs
PostPosted: Wed Oct 03, 2018 8:51 pm    Post subject: Re: M pto gasket Reply to specific post Reply with quote
just came in from doing just that scott. thanks. had to add a couple blocks to the idea tho. it came to me about 10 minutes after the evening beverage. Reds, I don't have the strength i did as a less old guy, 2nd heart attack fixed that. takes me forever in a day to get things done anymore. anyhow its sealed up and under a roof now and the road is almost dry so it can rain about daylight. hasnt rained here for about 36 hrs now so we are due...
fastfarmall
PostPosted: Fri Oct 05, 2018 3:27 am    Post subject: Re: M pto gasket Reply to specific post Reply with quote
But Fred, the good news is if it rains before 7,it will done by Eleven, and that you can put in the bank!
