What model to run a rototiller?
Goto page 1, 2  Next
CFB
PostPosted: Sat Oct 06, 2018 5:11 pm    Post subject: What model to run a rototiller? Reply to specific post Reply with quote
I've always had my eye on getting a 550 because it is a similar size as my 8N for my yard, but like I was told for my 8N, first gear is not slow enough to operate a rototiller.
I have a 30 year old 16hp Ford diesel tractor that I do all my mowing, rototilling and plowing snow with, but many parts are already discontinued and not available in any dealers inventory. I've started the research on subcompacts. But if I can do the rototilling with the larger tractor than I would not need to get it with the subcompact. And I would like a front end loader too.
What size/model Oliver would I need if desiring to get a tiller for it? gas or diesel.
I've not had to do too much on my 8N, just replacing all axle and pto seals, but that is about it. Are Olivers hard to work on? Should I be considering another brand for this job? I'm not even sure yet what year or decade to look at,but thought I'd start the conversation now.
thanks.
Traditional Farmer
PostPosted: Sun Oct 07, 2018 8:48 pm    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
Some of the Fiat built Olivers had slow enough gears to run a tiller,1365 would be real good.
CFB
PostPosted: Mon Oct 08, 2018 8:31 am    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
Thanks. You may have just answered if I need to go the subcompact route. The 1365 seems too big for me, but if that is sort of the minimum I would need, then I probably will forego that research.
Traditional Farmer
PostPosted: Mon Oct 08, 2018 8:51 am    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
You can run a tiller with any tractor that has a 3pt and PTO but the question is will it run a slow enough ground speed to till like it should.
CFB
PostPosted: Mon Oct 08, 2018 9:19 am    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
yes, so I guess what I'm looking for is what that slow speed is and what tractors have that slow speed.
John P.
PostPosted: Tue Oct 09, 2018 3:28 pm    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
At 1600 RPM for a 540 PTO speed, the Super 55 is only going about 1-1/2 MPH in first.
CFB
PostPosted: Tue Oct 09, 2018 3:52 pm    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
John,
is 1 1/2 mph ground speed what I'm looking for in a tractor to run a rototiller? Does the super 55 fit the bill therefore?
I better read up on them as I see some posts?
CFB
do you know if this site has a listing of what those Fiat built olivers were? thanks
scootergmc
PostPosted: Wed Oct 10, 2018 6:03 am    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
Start by reading this page and follow the links: http://www.importtractorparts.net/olivertractors.html
Just know parts will be probably be expensive if needed.
Don-Wi
PostPosted: Thu Oct 11, 2018 8:26 pm    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
A 550 would work just fine with a tiller. I've seen it done and it worked just fine.
Donovan from Wisconsin
Ollie03031
PostPosted: Sun Oct 14, 2018 1:41 am    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
I run a 5 ft tiller on my John Deere 790 which is 30 hp and it would also run ok on either of my Oliver?s 550 which are 40 hp.
rankrank1
PostPosted: Sun Oct 14, 2018 11:14 am    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
For a tractor purposely bought to run a tiller I would either want hydro static tranny or a gear drive unit that has creeper speeds in 0.7, 0.9, and 1.2 mph range with the engine at pretty much full rpm or whatever engine RPM achieves normal PTO speed of the implement.
I have a Kubota gear drive that has these really slow creeper gears in it. I imagine it would be handy as heck if I owned a tiller or a snow blower for that matter.
CFB
PostPosted: Mon Oct 15, 2018 11:55 am    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
rankrank1, would you mind sharing what year and model your Kubota is? thanks for those mph ranges. thank you. cfb
CFB
PostPosted: Mon Oct 15, 2018 12:01 pm    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
thanks. I believe a 550 is about 40 hp. I'll still check out what gears they have, but will keep it on the list to investigate.
I know with the 8Ns, some said they've used it with tillers but soil was softe. Mine is on the hard side.
CFB
PostPosted: Mon Oct 15, 2018 12:04 pm    Post subject: Re: What model to run a rototiller? Reply to specific post Reply with quote
thanks, I've read from other 790 owners of running a rototiller.
Goto page 1, 2  Next
Page 1 of 2
