ZTU Steering Bearings
Jerry Grant
PostPosted: Sun Oct 07, 2018 11:29 am    Post subject: ZTU Steering Bearings Reply to specific post Reply with quote
I am working on a total restore of a 37 ZTU. The worm drive steering shaft bearings and races are badly rusted. I have removed the shaft, removed the bearings and removed the races from the shaft and the adjusting plug. I have also removed the metal cap on the front of the pedestal. I can obviously see the race inside but there is no way to drive it out since the pedestal casting completely covers the race. Any ideas or suggestions?
Roger H MI
PostPosted: Sun Oct 07, 2018 12:35 pm    Post subject: Re: ZTU Steering Bearings Reply to specific post Reply with quote
If you want to remove the race. take a welder and run a small bead around the race. Should drop out.
Alan K
PostPosted: Sun Oct 07, 2018 4:02 pm    Post subject: Re: ZTU Steering Bearings Reply to specific post Reply with quote
Make sure there is a race there an not just machined cast iron before you go too wild. I will have to take a look in the parts books to make sure. Not sure on some of the early ones as a lot of times they just machined things right in castings such as camshaft bearings on the R and Z engines.
Jerry Grant
PostPosted: Sun Oct 07, 2018 5:41 pm    Post subject: Re: ZTU Steering Bearings Reply to specific post Reply with quote
You can tell there is a bearing race in there. My parts manual also shows a race. However, after taking some emery cloth to it, it doesn't seem bad at all. I think I will polish it up and leave it in there for now and see how it works.
Alan K
PostPosted: Sun Oct 07, 2018 8:42 pm    Post subject: Re: ZTU Steering Bearings Reply to specific post Reply with quote
If there arent any indents in the race from the old bearing Im sure it would be just fine with a good bearing.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
