JD 4020 Excess Smoke/Rocker Oiling Issue?
Goto page 1, 2  Next
Simplicity717
PostPosted: Wed Feb 21, 2018 8:16 pm    Post subject: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
Hello everyone,
This is my first post, but I have been lurking for a while now.
Long story short, the engine builder who rebuilt our diesel 4020 engine (ten years ago) didn't do it correctly, and the front timing gear popped off, allowing the valves to make acquaintance with the pistons haha. I installed all new components (timing gear, pushrods, etc.) had the head milled/inspected. Everything it put back together, timed correctly and it fires right up.
The issue I am having is that the engine smokes a little more at idle than it did before, and it smoke a lot more on acceleration (then clears up at constant RPM). I have tried loosening each injector and each one makes a difference (so it is running on all 6), one injector had to be replaced with a new one too. Any thoughts on this?
The other issue I have is it doesn't seem like any oil is making it to the top end. On any other engine you would see the oil running off of the valvetrain components, etc. On this one there doesn't seem to be much if any. The rocker shaft is aligned on the pin and the hole that I think supplies oil seems free. I blew air into it and I could her the air in the oil pan area. Any thoughts on this?
-Will
matthies
PostPosted: Thu Feb 22, 2018 5:35 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
Check to see if the rubber plugs are in the end of the rocker shaft, they get hard and will move in. The rear one can move enough to cause the oil to run out the rear of the shaft and not lube the rest of the rockers. The new ones are a bear to get in and if you can move the old plugs at all replace.
Simplicity717
PostPosted: Thu Feb 22, 2018 6:15 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
Ok so that is a point of contention that I had reassembling the rocker shaft. In the valvetrain explosion, the end cap of the rocker arm assembly came off. I actually ordered a new end cap and the rubber plug. I did not, however, put that rubber plug back in, because it would have interfered with the oiling hole. I don't even know why the rubber plugs are there, as the end caps have plenty of press fit to prevent any oil leakage. I'll take the rocker arm assembly off and see what I can discover. You would think that oil would come out of somewhere though?
-Will
matthies
PostPosted: Thu Feb 22, 2018 8:00 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
The shaft should have either the rubber plugs, having a cotter pin to stop it from coming out OR the steel cap. chris
D-
PostPosted: Thu Feb 22, 2018 11:08 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
Pull the rocker shaft and crank the engine to
see if oil is coming to the head.
As someone else said it's either/or on the plugs.
If there are small holes in the ends for cotter pins,
rubber plugs should be used. Otherwise steel plugs
are supposed to be used.
Look through the shaft to be sure an old plug hasn't
slid over the oil entering hole.
Simplicity717
PostPosted: Thu Feb 22, 2018 5:18 pm    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
10-4 That is what I thought! I checked the oil with the rocker shaft off and when cranking it comes out in splurts, but that is to be expected at the slow crank speed/that high on the engine. The rocker shaft is also not clogged and air shoots out of it in just the right places. I put it back together and called it a day, it seemed to be getting some oil. The black smoke also seemed to lighten up a little bit...
-Will
matthies
PostPosted: Thu Feb 22, 2018 7:09 pm    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
Early or late and precleaner above the hood?
Simplicity717
PostPosted: Thu Feb 22, 2018 7:47 pm    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
No precleaner
Simplicity717
PostPosted: Thu Feb 22, 2018 7:49 pm    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
It is a steel cap style, so no rubber plugs to go bad. I took the rocker shaft off and the oil does shoot out while cranking but it definitely has a pulse (like a fuel pump). The rocker shaft also holds air pressure and shoots air out of the right holes.
When reinstalled, it just seems like there isn't enough oil flow/maybe none. It is certainly no small block chevy with oil flying everywhere.
matthies
PostPosted: Fri Feb 23, 2018 5:48 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
So must be a side console? If so, look for a canister/filter on top of the air cleaner, has this ever been changed? Part number AR51923.
D-
PostPosted: Fri Feb 23, 2018 6:19 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
I wouldn't worry about it then if your oil pressure is OK?
Simplicity717
PostPosted: Fri Feb 23, 2018 11:01 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
Side Console, yes. Let me look into this. The only air filter I am aware of is the one in the air cleaner housing that is accessed by removing the side panel. That gets blown out every season.
-Will
Simplicity717
Going to check the OP and report back. I'll throw a gauge on it tomorrow.
-Will
Kent Petersen
PostPosted: Sat Feb 24, 2018 11:52 am    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
The oil will come in spurts that is because the only comes out as the hole in the cam lines up this is at the rear cam brg. you should check the inj psi setting all should be very close to the same
Simplicity717
PostPosted: Wed Feb 28, 2018 5:12 pm    Post subject: Re: JD 4020 Excess Smoke/Rocker Oiling Issue? Reply to specific post Reply with quote
It does come in spurts, the machine makes 30psi idle. I think it will be ok...
-Will
Goto page 1, 2  Next
Page 1 of 2
