NAA Clutch
cuby
PostPosted: Thu Oct 11, 2018 2:49 pm    Post subject: NAA Clutch Reply to specific post Reply with quote
A fella brought this to me today and the clutch will not release . It was working when parked 2 yrs ago but now will not release. This does not have the live pto but it does have live hyds. Thought about a split but if clutch is hung up I will probably not be able to get it apart. Any one been there done that and what have you done??
Thanks for all replys. You guys have been a great help in the past.
Bern
PostPosted: Thu Oct 11, 2018 3:28 pm    Post subject: Re: NAA Clutch Reply to specific post Reply with quote
Search the archives here - there are many posts on freeing up a stuck clutch. I could likely have it freed and the rust burned off in less than 5 minutes. Good working brakes are required to do it the quick way, which is not always a given on a NAA.
TimInd
PostPosted: Thu Oct 11, 2018 9:57 pm    Post subject: Re: NAA Clutch Reply to specific post Reply with quote
And from now on, put a wooden block under the clutch peddle to avoid this situation.
Sean in PA
PostPosted: Fri Oct 12, 2018 4:16 am    Post subject: Re: NAA Clutch Reply to specific post Reply with quote
CVPost-TimInd wrote:
(quoted from post at 01:57:38 10/12/18) And from now on, put a wooden block under the clutch peddle to avoid this situation.
Under???
Larry NCKS
PostPosted: Fri Oct 12, 2018 4:26 am    Post subject: Re: NAA Clutch Reply to specific post Reply with quote
Sean in PA wrote:
(quoted from post at 07:16:08 10/12/18)
Under???
My thought, exactly!
