ford 601 double clutch install adjustments
Ephratah
PostPosted: Fri Oct 12, 2018 1:46 am    Post subject: ford 601 double clutch install adjustments Reply to specific post Reply with quote
does any one have the measurements for a new double clutch install on a 601 workmaster I have an I&T shop service manual and it wants you to make a template to do this I would rather just measure it if possible this my buddies tractor and I am doing this as a favor for him. I own and operate an auto repair shop and this thing has one my 2 lifts tied up makes it tough to work with only 1 bay when you are used to having 2 bays. If any of you guys need help with any vehicle questions I can answer them for you not so much with tractors L.O.L.
Dean
PostPosted: Fri Oct 12, 2018 7:44 am    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
Not sure what you mean.
The double clutch assemblies used on vintage Ford tractors with so-called "live power" are factory adjusted.
Are you speaking of a pilot shaft?
Dean
Tom in TN
PostPosted: Fri Oct 12, 2018 9:40 am    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
Okay, Ephratah. Thanks for the offer of advice.
I have a 2005 Ford Ranger extended cab pickup. It seems that the "door-ajar" switch on the passenger's side has malfunctioned. I had this same problem on my former 1997 Ranger and the fix was to spray WD-40 into the latching mechanism on the door. Apparently the switch would get stuck and by spraying the lubricant into the latch mechanism, it would free-up the switch.
I've sprayed PB Blaster into the latch mechanism on this truck about 7 to 10 times and it hasn't fixed the problem. Any advice on how to proceed?
Thanks again for any help you can give.
Tom in TN
Dollar Bill
PostPosted: Sat Oct 13, 2018 12:23 am    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
Welcome to the forum - Glad to have you!!
If it's a reputable kit, you shouldn't need to adjust anything other than the pedal free play. Just to assure yourself it is correct I believe the 3 fingers for the transmission pressure plate should be 3/4" higher than the PTO pressure plate fingers.
Free Play Setting: 1½” - Turn the adjusting screw in to increase free travel or out to decrease free travel.
Clutch Adjustment: Lengthen the clutch release rod to decrease height and shorten to increase heights.
On 5-Speed transmissions, the clutch pedal can be repositioned to the 7” height for transmission clutch operation only. Relocate the clevis pin to the front clevis hole.
Ephratah
PostPosted: Sat Oct 13, 2018 2:50 am    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
i would unplug the connector at the latch and see if the warning goes away the latch provides a path to ground i tried to attach a wire diagram and it will not allow it
Ephratah
PostPosted: Sat Oct 13, 2018 2:53 am    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
thanks for the replies i was not aware that the clutch came factory preset and i do not trust factory settings i all ways verify plug gap prior to installing in a vehicle
Dean
PostPosted: Sat Oct 13, 2018 7:54 am    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
If you insist upon adjusting or verifying the adjustment, you will need a pressure plate press and the proper measuring fixture(s).
This is why the assemblies are factory adjusted.
Dean
Hobo,NC
PostPosted: Sat Oct 13, 2018 1:33 pm    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
On the last one I had apart I took the flywheel off bolted the clutch asy up to the flywheel and made tools to check it using a known good set up...
I now have tools to check clutch asy set up from a known good working unit if I can remember how to use it.
pomester
PostPosted: Sat Oct 13, 2018 9:53 pm    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
related, check carefully the condition of the bolts holding the pressure plate to the flywheel - they are special shouldered bolts and on the last on I did they were stretched and needed replaced -
Ephratah
PostPosted: Wed Oct 24, 2018 2:27 pm    Post subject: Re: ford 601 double clutch install adjustments Reply to specific post Reply with quote
Thanks for the help got it back together and running still have some bugs to work out but getting closer
