Farmall 100 starter not engaging
grampsh1
PostPosted: Fri Oct 12, 2018 8:23 am    Post subject: Farmall 100 starter not engaging Reply to specific post Reply with quote
New battery tractor started well tractor has set for couple months went start today pulled starter switch nothing half turn with hand crank running starter switch new year ago thinking corroded contacts in switch what can I put on contacts after polishing to prevent ground connection from battery cleaned when battery changed any other suggestions if not switch starter rebuilt a year ago
rvirgil_KS
PostPosted: Fri Oct 12, 2018 9:14 am    Post subject: Re: Farmall 100 starter not engaging Reply to specific post Reply with quote
Check and clean both ends of both battery cables. Connections must be clean and tight. If cables or clamps look corroded replace them. Tractor end of the ground cable should go to a bolt on the main frame as close to starter as possible, not through rusty battery boxes and sheet metal.
Janicholson
PostPosted: Fri Oct 12, 2018 9:57 am    Post subject: Re: Farmall 100 starter not engaging Reply to specific post Reply with quote
The switch may need its holes ovaled to allow it to touch the lug. Jim
C.Amick
PostPosted: Fri Oct 12, 2018 4:26 pm    Post subject: Re: Farmall 100 starter not engaging Reply to specific post Reply with quote
Make sure the battery cable ground connection is clean at the tractor body.
grampsh1
PostPosted: Sat Oct 13, 2018 4:00 am    Post subject: Re: Farmall 100 starter not engaging Reply to specific post Reply with quote
grampsh1 wrote:
(quoted from post at 09:23:28 10/12/1Cool New battery tractor started well tractor has set for couple months went start today pulled starter switch nothing half turn with hand crank running starter switch new year ago thinking corroded contacts in switch what can I put on contacts after polishing to prevent ground connection from battery cleaned when battery changed any other suggestions if not switch starter rebuilt a year ago
thanks for suggestions I will try all these and reply back
grampsh1
PostPosted: Sat Oct 13, 2018 8:58 am    Post subject: Re: Farmall 100 starter not engaging Reply to specific post Reply with quote
grampsh1 wrote:
(quoted from post at 05:00:02 10/13/1Cool
remove band covering brushes on starter commutator very dirty removed starter disassembled polished commutator brushes fields on stator lubed removed switch on starter holes were already elongated but contacts corroded polished all contact points wire wheeled all contact points of starter case before reassemble and bell housing contact point cleaned both ends of battery cables and battery posts put all back together and presto starts like brand new thanks for all the suggestions really appreciate the support Paul
